June 01, 2023, 02:12:16 AM
Author Topic:  Gearhead Intercooler Review  (Read 35555 times)
Offline jus2quik
  • Jr. Member
  • Jacksonville,Florida
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
  • Liked:
  • Likes Given: 0
Re: Gearhead Intercooler Review
« Reply #45 on: August 02, 2019, 07:14:42 PM »
Got my intercooler in today,so far it has been awesome,install was perfect,so far my temps have dropped substantially and the car seems to just pull harder and more consistant, no sign of lag or a build up of boost just smooth strong pull along with low temps that drop the harder it goes . I usually see temps in the 150-180 range here in Florida .Today I saw no higher than 120 degree temps and as low as 109 around town . Glad this product was so easily available and it literally was at my door in just a few days .
Basic beginner mods :GH tune,3Bar MAP,colder plugs,Drop in filter,160 Tstat
Offline jus2quik
  • Jr. Member
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
  • Liked:
  • Likes Given: 0
« Reply #46 on: August 02, 2019, 07:15:51 PM »
It’s also amazing how fast after my order that I received my new tune via email,thanks again for providing awesome products fellas
Offline Gray Brick
  • Sr. Member
  • Southern California
  • Thank You
  • -Given: 34
  • -Received: 108
  • Gray Brick
  • Liked:
  • Likes Given: 0
« Reply #47 on: August 03, 2019, 12:42:17 AM »
How much thicker is the new Gearhead intercooler compared to the stock one?
2013 Ecoboost Ford Flex
Offline Jordan
  • Elite Member
  • Columbia, Mo
  • Thank You
  • -Given: 224
  • -Received: 643
  • I'm the captain of this SHIP
  • Liked:
  • Likes Given: 1
« Reply #48 on: August 03, 2019, 12:58:08 AM »
GH one is about 2" thick compared to like .75" thick on stock.
Offline Gray Brick
  • Sr. Member
  • Thank You
  • -Given: 34
  • -Received: 108
  • Gray Brick
  • Liked:
  • Likes Given: 0
« Reply #49 on: August 03, 2019, 12:30:06 PM »
Wow!!! Very nice.
Hopefully the phenolic spacers will be created for our manifold so we can bring down the iat even further.
Offline StealBlueSho
  • Elite Member
  • Thank You
  • -Given: 2957
  • -Received: 2854
  • Liked:
  • Likes Given: 59
« Reply #50 on: August 03, 2019, 07:37:39 PM »
IC works greats when moving.... sitting in the pits and staging lanes is always a problem... hence why tracks always run out of bagged ice.
Offline SM105K
  • IG @fafomotorsports
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 1049
  • -Received: 1224
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 31
« Reply #51 on: August 04, 2019, 12:05:14 AM »
100 percent accurate. Once it is heat soaked....donzo.
Offline mrhighcaliber
  • Full Member
  • Thank You
  • -Given: 322
  • -Received: 159
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #52 on: August 20, 2019, 07:14:08 AM »
Wow!!! Very nice.
I've been wishing for a thermal isolation spacer for our platform.
Sent from my PH-1 using Tapatalk
Offline Gray Brick
  • Sr. Member
  • Thank You
  • -Given: 34
  • -Received: 108
  • Gray Brick
  • Liked:
  • Likes Given: 0
« Reply #53 on: November 06, 2019, 05:31:51 PM »
I got tired of waiting and created a CAD file for the spacer...
Getting it cut now.
If anyone is interested in one please PM me.
Offline bpd1151
  • Forum Supporters
  • Elite Member
  • SHOcago S/W 'Burbs
  • Thank You
  • -Given: 2611
  • -Received: 2679
  • SHOGAZM
  • Liked:
  • Likes Given: 0
« Reply #54 on: November 06, 2019, 07:18:54 PM »
Getting it cut now.
PM sent.
Offline 802SHO
  • Currently World’s Fastest Ecoboost SHO
  • RotM Winner
  • Elite Member
  • Essex Junction Vermont
  • Thank You
  • -Given: 2431
  • -Received: 1157
  • Boosted
  • Liked:
  • Likes Given: 7
« Reply #55 on: November 07, 2019, 07:06:57 AM »
Getting it cut now.
^^^ Excellent!  Glad you stepped up and took control of this!
* Recent Topics
Re: 1st time owner
by SHOdded | May 15, 2023, 04:39:13 PM
nice ride, nice wheels. welcome and congrats!...
Re: New Member from Cincy
by PDSHO | May 14, 2023, 09:34:42 PM
Greetings from Nebraska.Also Go Bengals!Greg...
Re: White Smoke, Shuddering on brand new turbos
by jordanc67 | May 09, 2023, 12:54:12 PM
idk if this is the case here but apparently white smoke can also be ca...
Re: New 3 bar MAP - Now engine surges and multiple dash error lights
by SHOdded | May 08, 2023, 06:30:31 PM
if you replaced the 2 bar map with a 3 bar and did not tune for it, th...
Re: 3rd cat & resonator delete feedback
by kryptto | May 08, 2023, 05:27:41 PM
Do you mind sharing the part number ofDescriptions.  Or should I ...
Re: BOV - truths - education
by kryptto | May 08, 2023, 05:12:46 PM
Hey all, just an update and I am sure it won't be a surprise.&nbs...
Ford Taurus Sho makes grinding noise
by Mnelson | May 08, 2023, 11:11:49 AM
My ford Taurus sho usually makes a grinding noise when the tires spin....
Re: RockAuto.com Discount Code - Expires October 5, 2022
by SHOdded | May 06, 2023, 04:25:00 AM
idk if rockauto is still monitoring this site. but in the meantime, go...
Re: Piggy back vs flash tune. Which is best?
by Macgyver | May 03, 2023, 02:00:29 PM
Non E 91 is a good choice.5000 ft is tough on turbo output but the tun...
Re: UPR catch can kit
by Macgyver | May 03, 2023, 01:58:56 PM
Ford OEM rotors are bad. Same issues with the Edge ST. PP rotors are b...
