October 15, 2019, 09:45:33 PM
Author Topic: Gearhead SHO/Flex Intercooler Install Video  (Read 1778 times)
Offline Leadfoot
  • Full Member
  • : eastern PA
  • -Given: 13
  • -Received: 31
Re: Gearhead SHO/Flex Intercooler Install Video
« Reply #15 on: June 19, 2019, 10:53:16 AM »
I recalibrated my SHO, unfortunately with a MKS/Flex hybrid calibration in which 4 of the adapter plates were slightly off center, but with a bamboo punch I was able to reconfigure the main and positive straight wires with just enough room to establish a neutral resonance. This did not cause any distruption in the Gearhead intercooler interface even after adding .37% more volts via the more pliable conduit. Hope this helps...
Made me think about the Turbo encabulaor :-)
https://www.youtube.com/watch?v=jk_QxHQHM1s
2018 Taurus SHO White, non pp (ACC) 20/35% tint, ceramic coating, hot pipes, PPE catted down pipes, LMS V11 tune, 170 degree t-Stat. Still need to install the gauge pod...
Traded in (minus some parts): 2013 Taurus SHO black non pp (ACC) 20% tint, Gauge pod, H&R Springs, LED puddle lights, LMS V11 tune,170 degree T-stat, Hot pipes, 3 bar map, PPE catted downpipes. PP suspension, Power Stop brake kit.
Offline MKS Tom
  • Full Member
  • : PA
  • -Given: 34
  • -Received: 41
  • Weirdo
« Reply #16 on: June 21, 2019, 02:12:36 AM »
Future purchase for sure.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #17 on: July 08, 2019, 02:47:33 PM »
FYI- I guess better late than never but removed my Intercooler from underneath the vehicle! If you have access to a lift you can remove the IC from underneath the vehicle by first removing the Condenser,cooling Fans and then the Intercooler which ultimately will cut the Install time by almost Half! Z  :)
BTW Once again Big Thanks to Matt over Gearhead for the awesome upgraded IC!   :thumb:
« Last Edit: July 08, 2019, 04:37:25 PM by ZSHO »
Offline Agentlongwood
  • Sr. Member
  • : Central Florida
  • -Given: 17
  • -Received: 145
« Reply #18 on: July 08, 2019, 03:25:25 PM »
That's pretty interesting Z.  I don't have a lift so I couldn't use that method.  But I am interested in learning what all you did.  What steps do you skip that save you so much time?
2014 Lincoln MKS - 3 Bar MAP sensor, AEM Dryflow, 170* t-stat, sp534 plugs @ .030, Amsoil top shelf stuff in the motor/trans/PTU/RDU, AJPturbo 93 Octane tune.  Child car-seat in the back, stroller in the trunk. wife zonked out in the passenger seat with the heater/massage going...
13.048 @ 104.74 with a 60 foot of 1.847
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #19 on: July 08, 2019, 03:42:44 PM »
I used a buddys lift which made life much easier as everything essentially slid out of place from underneath when compared to pulling the Condensor and Intercooler plus cooling Fans from up TOP of the engine!
I still had to remove the bumper cover and (Passengers side) headlight assembly which was pretty much straightforward besides some broken miscellaneous clip pieces.
I think it took me roughly 3.5 hrs time with assistance from a buddy of mine for bumper removal/install. Z
« Last Edit: July 08, 2019, 06:13:21 PM by ZSHO »
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havenít had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
