- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: ZSHO on January 22, 2019, 06:06:42 PM
I found out that there is an updated new Progressive controller LED activation light that will not only will it ramp in boost but also RPM so it ensures that Meth quantity increases with RPM as well available for in house installs. Z
Interesting. Nothing wrong with making sure there's adequate delivery at all times. Nice new safety feature. Does this mean it can assist if an issue arises...if boost and rpm are out of sync?
