E85 concentration above 85%?
Started by StinkinLinkin13, January 22, 2019, 03:00:42 PM
StinkinLinkin13
So I'm getting ready to run an e30 tune and I tested the e85 at my local gas station with the tube water+ E85 gauge I bought online... According to this method/gauge the concentration of e85 is actually higher than 85%... roughly 87%. Has anyone else ever seen a high concentration like that? Everything I've read states 83% to be the max and that is supposedly rare. Just curious.
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
StinkinLinkin13
E87...? 🤔
SM105K
Back in the day here in PHX I was seeing E90.
Macgyver
We had this earlier in the year in Pa.
StinkinLinkin13
Well thats good news... I have been reading about reports of people finding it as low as 40%... Which from my understanding is lower than regulation. This is the only gas station I've tested so far in my area. Being it is my usual stop I just went ahead and used it since the rating was much higher than I expected... 😎
SM105K
Quote from: StinkinLinkin13 on January 23, 2019, 02:09:54 PM
In Phoenix we used to have around e90 ish.  However, we became a flex fuel state, and now it runs e54.  So yeah.....
SM105K
Quote from: SHOdded on January 23, 2019, 05:06:53 PM
well that sux about e54 ...
I look at the bright side of it.  I think with a upgraded HPFP, pump e54 will perfect for what I want to. Quick test, verify it is e54, pump straight into car, have Brad turn her up to 110%, let her ride.
f8tlSHO
If it's e54, you save money on fuel... corn gas is cheaper than 93 by a dollar here. To get your e30 you need more corn gas this way... as long as it's consistent I'm ok with it. Mine runs about e70 most of the time
