So, I come to you, (good people of the forum), with hat in hand. I got into a not so hard, (so i thought), Fender bender. A smack in the Front passenger corner. I have had the car in a shop for a month waiting on replacement parts/paint to arrive. I went to pick up the car today and low and behold the body work looks real good. If it weren't for the new headlight you really cant tell. However, Now I have some Electrical gremlins as well as some steam venting from the radiator.
My first question to you good people is, how hard is it to crack a Radiator on these cars, and if it is cracked could I also have a bad inter-cooler? There is NO water leaking to the ground, its just light amounts of steam. Also the Radiator fans are not turning see below...
Second Question is for the electrical gremlins, I have a few indicators, Check Battery Charging message, the Center touch console is not working, the touch screen is working but I have no environmental controls, Heat/Front Defrost is stuck on full blast. The Airbag dash Light is constant ON and the Radiator fans are NOT turning. There are two Codes that are being picked up by the shops scanner but not my handheld, U0557 (invalid data received from front controls), U0256 (lost communication with front controls).
Anyone know where I can tell them to look for the loose connections? These electrical issues were NOT present when I dropped the car off for body work, I drove it for almost 2 days after the fender bender with Zero issues. I dont remember there being any steam vent issues either.
Do you think that the Rad is possibly fine but venting due to the fans not turning? The venting seems to be coming from the Drivers side of the Rad, (opposite side of the accident). Any Advise I can get from you to give this shop in order to get my car back on the road would be greatly appreciated. I am stuck with this shop unfortunately, for overseas insurance reasons, (Germany).
