Interceptor wheels with snow tires
Started by Chris_Flex, December 28, 2018, 08:40:49 PM
Chris_Flex
Thinking about picking up a set of 18x8 police interceptor rims and buying some snow tires anyone have these as there winter set up? What size snow tires are you running
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
Not running these wheels but I believe the correct size would be
245/55/18
EDITORIAL NOTE:  This size fits a Taurus.  Post modified by admin on behalf of glock-coma.
Gjkrisa
Im running steel rims with blizzak SUV tire that are made to handle 140 mph
My wife had the tire guy pick it out as she didn't want to spend the money on higher quality winter tires  when I was away from home
But they work pretty well
I would of rather used the inticeptor steel rims since it has a center cap mine do not and you can see the middle nut getting rusty.
There was no rust the first time I swapped the tires.
Chris_Flex
I found a set at a local salvage yard for $350 and he said If the center caps are there I can have them also sound like a good deal?
BC Coilovers
Trans mounts
Unleashed e30 Tune
5ohSHO
My P.I. had a set of Firestone Fire Hawk PVS tires on it when I bought it and they were amazing in the snow, but they're crazy expensive. I currently have Toyo Celsius on my SHO and they perform pretty good and aren't priced too bad.
Chris_Flex
Quote from: 5ohSHO on December 29, 2018, 11:31:31 AM
I think I'm gonna try the Goodyear ultra grip I found a set on tire rack with rebates for $425
BC Coilovers
Trans mounts
Unleashed e30 Tune
Sorry, can't edit my original post. I didn't realize these were for a flex, the size I gave you was for the Taurus
Chris_Flex
Picked these up for 300 today with TPMS they didnt have any decent center caps so I'm gonna have to look elsewhere
BC Coilovers
Trans mounts
Unleashed e30 Tune
Chris_Flex
Quote from: ZSHO on December 30, 2018, 07:01:51 AM
The PI Center caps are not cheap with some fitment issues while being on backorder IIRC!  Z
https://www.ecoboostperformanceforum.com/index.php/topic,8613.0.html
https://www.hubcaphaven.com/c/2019/ford_taurus_center_caps.html
https://www.fordpartsgiant.com/parts/ford-cover-wheel_dg1z-1130-b.html
Thanks for the info. Il get the right lug nuts and run them with no center caps for now and keep checking salvage yards, new ones are too expensive
BC Coilovers
Trans mounts
Unleashed e30 Tune
Maybe coat the lugnuts with some dielectric in the meantime?  I do not know what would work to keep the rust away.  Maybe paint, LOL.
Chris_Flex
Quote from: SHOdded on December 30, 2018, 10:45:28 AM
I planned re painting the wheels and maybe il just use my stock closed lug nuts until I get center caps
BC Coilovers
Trans mounts
Unleashed e30 Tune
Chris_Flex
I don't know why I didnt think of it earlier but my work has used Ford Rangers for 20+ years as escourt trucks for oversized loads.
Stopped at the garage this afternoon and picked these up for free today! I know there not the exact Interceptor hub caps but these are better then nothing just need to order lug nuts and should be able to get them on next week.
BC Coilovers
Trans mounts
Unleashed e30 Tune
