January 20, 2019, 03:07:58 PM
Author Topic: Help - 150k miles PTU Output Shaft Rotational End Play  (Read 284 times)
Offline abs
  • Newbie
  • -Given: 2
  • -Received: 2
« on: December 27, 2018, 06:18:13 PM »
I have a 2010 EB Flex with an original PTU and about 150k miles.  I'm trying to determine if the PTU needs replacement due to excessive wear.  It's out of the car right now as I'm doing a transmission/torque converter replacement.
The PTU does not whine and rotates smoothly.  However, when I change the rotation of the output shaft it makes a clicking noise and there is some rotational play in the output shaft.  I made a video to show what I'm talking about here:
https://www.youtube.com/watch?v=aNQz4Qw0v9k
Would love some advice from the expert folks here who have had more experience with these units, both new and used, to determine if what I'm observing indicates I should replace the unit.
A bit of history about this unit, I've changed the fluid using the evacuation method every 30k miles since there was 60k miles on the odometer, so it's been fairly well maintained since then.
https://www.fordflex.net/forums/viewtopic.php?f=7&t=9334&p=106997&hilit=ptu#p106997
Thanks in advance,
Andrew
« Last Edit: December 27, 2018, 06:20:23 PM by abs »
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1180
  • -Received: 2727
Re: Help - 150k miles PTU Output Shaft Rotational End Play
« Reply #1 on: December 27, 2018, 07:06:31 PM »
I'm not quite certain on this but allowing the intermediate shaft to rotate while it is disconnected from the gear or damage to the clockspring may occur. If there is evidence that the intermediate shaft has rotated,the (clockspring) must be removed and recentered!
Im hoping others will chime in.
BTW Due setup an Intro @ your earliest convenience.TIA. Z
https://www.ecoboostperformanceforum.com/index.php/board,14.0.html
« Last Edit: December 27, 2018, 07:11:14 PM by ZSHO »
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|Airaid-Dry-flow-CAI|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned @ 415whp-465wtq| Best Trap Speed of 115.54 mph|
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 9787
  • -Received: 3252
« Reply #2 on: December 27, 2018, 08:20:27 PM »
A couple of members have replaced their own PTUs and/or worked with issues on the output shaft (to driveshaft), so they likely will have more insight on the "play" issue.  Otherwise, nothing seems out of the ordinary in the video.  No noise at all but for that output shaft as you rotated it.  Assuming the low rpm results correspond to high rpm results, of course.
Was there a pre-existing leak from the output shaft prior to PTU removal?  In that case you would want to replace the seal at the very least.  You have to index the output flange and the driveshaft so the driveshaft balance is maintained.  Else the driveshaft has to be rebalanced.
As far as movement of the intermediate shaft, not sure if the clockspring is affected when the shaft is moved with the PTU already off the vehicle.  I don't see why it would, but IDK 4 sure.
« Last Edit: December 27, 2018, 08:23:04 PM by SHOdded »
Offline abs
  • Newbie
  • -Given: 2
  • -Received: 2
« Reply #3 on: December 28, 2018, 07:10:35 AM »
ZSHO and SHOdded:
Thanks for your replies.  The rear output shaft seal has never leaked on this PTU.  At one point I had a leak at the passenger half-shaft output location (I think this seal has failed for many of us), but that seal was replaced (twice actually) and has not leaked in years.  I'm certain that rotating the PTU while it is off the vehicle will not effect the clock spring since the clockspring is in the steering wheel and not the driveline.  I did also mark the rear drive shaft and PTU output flange so they can be properly reinstalled with the same position.
Thanks,
Andrew
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 9787
  • -Received: 3252
« Reply #4 on: December 28, 2018, 08:56:44 AM »
i think you are all good to go then.  your call if you want to replace the output shaft seal.  seems to be doing fine to me, and you can do it later if need be.  yes ideally the flange should be locked and immovable, but it is out of the vehicle so it will not behave the same.  Check once reinstalled - in P and N, the driveshaft should not rotate at all.  Keep up the good work with the fluid changes - PITA, but obviously paying off for you :thumb:
Offline glock-coma
  • Forum Supporter!
  • : Parma,Ohio
  • -Given: 567
  • -Received: 668
« Reply #5 on: December 28, 2018, 01:22:54 PM »
I still have my old PTU all though the gears have been removed from it. The flange and pinion gets are still intact.
I think what youíre hearing is the
 hypoid gear inside making contact where the pinion and the ring gear meet.
There will alway be some play between the surfaces. As long as youíre not seeing debris in your oil when you change it I would think the wear would be minimal.
I can get a pic later if it will help.
Offline 4sfed
  • Full Member
  • : St. Louis, MO
  • -Given: 62
  • -Received: 21
« Reply #6 on: December 28, 2018, 01:27:24 PM »
May I ask why your PTU internals were removed?  Was it bad (or failing), and this was lesser expensive solution?  Or did you just not want AWD anymore?  Some other reason?
Factory Five Mark III, 2004 Mach I donor (gone)
2003 Mustang Cobra 'vert, 456 rwhp, with mods (gone)
2002 MB C32 AMG (gone)
1997 Cobra 'vert, Vortech'd (gone)
Offline glock-coma
  • Forum Supporter!
  • : Parma,Ohio
  • -Given: 567
  • -Received: 668
« Reply #7 on: December 28, 2018, 01:29:59 PM »
No my PTU went bad, one of the bearing races disintegrated and cause total failure.
I kept the old one to dissect
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1180
  • -Received: 2727
« Reply #8 on: December 28, 2018, 01:34:15 PM »
I thought a new shaft seal was recommended anytime the PTU is removed from the vehicle!!  Z
« Last Edit: December 28, 2018, 02:03:09 PM by ZSHO »
Offline glock-coma
  • Forum Supporter!
  • : Parma,Ohio
  • -Given: 567
  • -Received: 668
« Reply #9 on: December 28, 2018, 01:36:08 PM »
Hereís a preview from a pic I have saved on my phone.
Offline glock-coma
  • Forum Supporter!
  • : Parma,Ohio
  • -Given: 567
  • -Received: 668
« Reply #10 on: December 28, 2018, 01:38:33 PM »
The driveshaft where it connects to the PTU does have a clock spring per the manual. They donít want you rotating the drive flange
Offline 4sfed
  • Full Member
  • : St. Louis, MO
  • -Given: 62
  • -Received: 21
« Reply #11 on: December 28, 2018, 01:53:31 PM »
Wow!  Yikes!  ...you let all the magic metal flakes out.
Offline glock-coma
  • Forum Supporter!
  • : Parma,Ohio
  • -Given: 567
  • -Received: 668
« Reply #12 on: December 28, 2018, 01:56:21 PM »
Hereís a picture of the pinion and ring gear.
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 9787
  • -Received: 3252
« Reply #13 on: December 28, 2018, 03:31:31 PM »
May be thinking of the compression seal?  Between trans and PTU?
https://www.autoserviceprofessional.com/article/95195/leaky-ford-ptu
It mentions to replace both seals, the compression and link shaft (ptu to halfshaft) seals, which makes sense since both are "violated" when the PTU is removed.  The output shaft seal however remains intact, as the output flange is not touched.
« Last Edit: December 28, 2018, 03:33:12 PM by SHOdded »
* Featured Topics
* Recent Topics
Re: New Intercooler for Transverse 3.5L Ecoboost
by Josephm | Today at 02:40:38 PM
This will be huge for towing!!! I am waiting for a couple of install v...
Re: 2013+ intercooler install?
by ddlopes | Today at 01:59:33 PM
Can hot pipes still be used with this intercooler? And does anyone kno...
Re: Ecopowerparts 09-14 F150 widebody kit
by 802SHO | Today at 12:19:16 PM
That looks bad a$$!  It's perfect in all the right spots...i...
by BoostfoSHO | January 19, 2019, 05:14:53 PM
New Alky pump ordered from www.Alkycontrols.comI emailed Julio over @ ...
Re: New member here transferring from other forums
by TonyTheTiger57 | January 19, 2019, 03:57:46 PM
No, there isn't a particular reason I like Fords.. It just happen...
Re: Ford Expedition & Lincoln Navigator
by ZSHO | January 19, 2019, 11:01:11 AM
2019 LINCOLN NAUTILUS RECALL ISSUED FOR 2,700 SUVSLincoln SUVs have pr...
MOVED: Toyota ecoboost
by ZSHO | January 18, 2019, 04:26:04 PM
This topic has been moved to Admin-Moderator only discussion.https://w...
Re: Throttle Body Motor assembly
by ZSHO | January 18, 2019, 06:22:19 AM
Feel free to start your own Dedicated thread here! Z https://www.ecobo...
Re: 2012+ timing job
by ZSHO | January 17, 2019, 06:28:58 PM
I believe so!  Z https://drive.google.com/file/d/0B8JUL90DXgdiMTZ...
by ZSHO | January 17, 2019, 05:16:56 PM
JAN 14, 2019 | FORD MOTOR COMPANY PRESS RELEASEALL-NEW FORD EXPLORER G...
MOVED: Looking for used Cat-Back for A 2014 SHO
by ZSHO | January 17, 2019, 04:25:11 PM
This topic has been moved to Parts for Sale or Wanted.https://www.ecob...
Re: Splash blending e85 to 93
by FiveLeeter918 | January 17, 2019, 01:44:28 PM
Thanks to everyone! To prevent any fuel related issues god forbid I ru...
Re: Livernois Upgrades
by Livernois Motorsports | January 17, 2019, 07:45:34 AM
I just wanted to share my recent experience with Livernois and my 2018...
MOVED: Livernois Upgrades
by SHOdded | January 16, 2019, 08:09:34 PM
This topic has been moved to Livernois Motorsports and Engineering.htt...
Re: Something different?
by SHOdded | January 16, 2019, 04:29:39 PM
LOL, yes, my reference was the first gen V's, since people buy th...
Back to top
