Livernois Motorsports taurus SHO catch can release
Started by Livernois Motorsports, December 18, 2018, 05:43:31 PM
802SHO
Quote from: sm105k on December 19, 2018, 01:18:34 PM
802 I am pretty sure the MKS and SHO are the same.  I know the Flex and the SHO are same.  I have a "FLEX" catch can on my SHO.
Quote from: ZSHO on December 19, 2018, 01:48:27 PM
Don't forget about the beloved MKZ!  Z  :D
MKZ!!  Sorry fellas I meant to say MKZ not MKS...is there even such a thing as an MKS?  Lol!  And the Flex too!  Sorry...working on the mind to mouth thing.....😵😇
SM105K
Lol, there is such a thing as an MKS.  They are the Lincoln version of the SHO.
shoNoff
What's a Lincoln? I didn't know honest Abe built cars.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
802SHO
Quote from: shoNoff on December 19, 2018, 02:21:45 PM
Lol he did and apparently couldnt choose between an MKS and MKZ and so he made both!  What is the difference between the two?  I was thinking of the one that was the sedan similar to the SHO.  Are they both sedans and both 3.5 Ecoboost?  So confused...reminds me of my first date...
Quote from: 802SHO on December 19, 2018, 01:12:34 PM
People looking on and searching your site might not know that it does fit their 2010-12 and perhaps instead of asking look at a different vendor site for it.  But if they saw that it said 2010+ then they likely would add that to their cart.  And if it fits the Explorer and MKS then thats even more units sold!
Once we get one in here and verify we will update the website so no worries, it shouldnt be long before we get one that is local here
shoNoff
Quote from: 802SHO on December 19, 2018, 02:24:21 PM
MKS = SHO
MKZ = Fusion
Your first date sorry buddy can't help you there.
I think the website needs to be updated AFAIK!  Z
The SHO & FLEX have different part numbers and price-point...
It does look like a solid unit but No Bueno for us METH Guys/Gals due to insufficient room due to the washer fluid in place....
I'm quite certain everything will be updated in no time.  :)
SHO- https://www.livernoismotorsports.com/product/LPP453903
FLEX- https://www.livernoismotorsports.com/product/LPP453901
Quote from: ZSHO on December 19, 2018, 04:22:23 PM
It does look like a solid unit but No Bueno for us METH Guys/Gals due the washer fluid in place....
I'm sure everything will be updated in no time.
This shows the universalcatch can part number that would need brackets, hoses, ect. Before we add it for these vehicles we need to put them on the vehicle first and verify before we go around claiming it will work, i understand the setup it virtually the same but without it on the car here we do not want to say it will work
Quote from: Livernois Motorsports on December 19, 2018, 04:40:31 PM
Confirming fitment first is always plausible..Nice product indeed. Z   :thumb:
SM105K
What exactly is Livernois' Stance on the catch can?  Clearly if you are offering one, your R&D department believes the DI motor benefits from this?
802SHO
You got to make room Z!  The canister fits with the bracket connected but the mini windshield washer fill tank is in the way of one of the connections.  I took the screws out that held the mini WW tank in place and let it hang down a bit and I also ended up not attaching the bracket.  Both are in place and wedged really well...so well in fact that this temporary fix has ended up more of a permanent situation.  Id like to see it cleaned up better, things moved a bit more, maybe even relocate the mini WW fill tank...but bc it's secured without actually being secure this is how it remains today.
Quote from: ZSHO on December 19, 2018, 04:48:26 PM
We appreciate the compliments as always thanks!
Here is a picture of the new catch can installed on a vehicle!
Davidsiebert2
Just left Cody a voicemail. I work not to far from you guys and could stop in this week so you can verify the 2010-2012 fitment of the can . For the small price of making me a deal on making a pull with my E30 ajp tune  ;D
Quote from: Davidsiebert2 on January 09, 2019, 04:23:54 PM
Welcome and due setup an intro with your current vehicle and any mods you may have! TIA.  Z
https://www.ecoboostperformanceforum.com/index.php/board,14.0.html
