March 25, 2019, 05:08:34 AM
Author Topic: Ecoboost basic swap info  (Read 568 times)
Offline lamrith
  • : PNW
  • -Given: 105
  • -Received: 347
« on: December 11, 2018, 11:11:09 AM »
I am wondering if there is a way we can get some information compiled in one place and make it a Sticky?
I do not have the answers to any of this, but was just debating a possible swap and realized this was critical information needed to make a decision that would make for a good sticky thread here in the Swap area.
If I missed one or have any of them wrong below let me know, I will update the OP as I get information.  Also if there is additional info
CAR/SUV AWD 3.5ECO (Transverse mount):
  • Engine Type: Transverse Mounted twin turbo V6
  • Length In(mm):
  • Height In(mm):
  • Width at heads  In(mm): 22" (559)
  • Width at widest with fact. turbo  In(mm):
  • Width at oil pan  In(mm):
  • Weight lbs (kg):449(203)
  • RPM Range:
  • Bellhousing pattern:
  • Factory trans options:
  • Factory HP: 365 @ 5500rpm
  • Factory Tq (lb/ft): 350 @ 1500-5000rpm
CAR 2.0ECO (Longetudenal mount):
  • Engine Type: I4
  • Length In(mm):
  • Height In(mm):
  • Weight lbs (kg):328 (149
  • RPM Range:
  • Factory HP: 240@5500rpm
  • Factory Tq (lb/ft): 270 @ 1900-3500rpm
CAR 2.7ECO (Longetudenal mount):
  • Engine Type: V6
  • Length In(mm):
  • Height In(mm):
  • Weight lbs (kg):440 (200)
  • RPM Range:
  • Factory HP: 315 @ 4750rpm
  • Factory Tq (lb/ft): 350+ @ 2750rpm
TRUCK 3.5ECO (Longetudenal mount) dimensions/specs:
  • Engine Type: Longetudenal mounted Twin Turbo V6
  • Length In(mm):
  • Height In(mm):
  • Width at widest with fact. turbo In(mm):  28.5 (724)
  • RPM Range:
  • Factory HP: 365 @ 5000rpm
  • Factory Tq (lb/ft): 420 @ 2500rpm
« Last Edit: December 22, 2018, 09:10:01 PM by lamrith »
'13 Sho PP, SCT x4, AJP 92-Octane rev6 (14psi&20spark) NGK 6510, 3Bar, K&N CAI, PPE Catted DP, Dynomax Axleback, H&R's, 20*9.5 Voxx Lago.
Offline lamrith
  • : PNW
  • -Given: 105
  • -Received: 347
Re: Ecoboost basic swap info
« Reply #1 on: December 22, 2018, 10:09:16 PM »
Few updated from a wiki I found.  Still no detailed measurement info though which for a conversion is the most important aspect.
https://en.wikipedia.org/wiki/Ford_EcoBoost_engine#3.5_L
* Featured Topics
* Recent Topics
Re: First new year outing guesses 3/24
by Jordan | Today at 04:50:44 AM
Here is an unedited video of the fastest run of the day.https://www.yo...
Re: Catch can,air/oil seperator, vent to atmosphere?
by ZSHO | Today at 04:00:28 AM
Here are a couple PICS of the CFM PERFORMANCE BILLET VALVE COVER BREAT...
Re: Dead 100% battery symptoms??
by 802SHO | Today at 02:42:22 AM
Ok...Money no object!!!!!  HHEHEHE.  Has anyone else seen th...
Re: Transmission drain and fill
by BlueSHO | March 24, 2019, 08:15:58 PM
I think he was asking about a drain and fill which I believe is about ...
by Jordan | March 24, 2019, 06:15:08 PM
What was the Total in weight reduction ? Znot sure, but let's say...
Re: Help me Diagnose Knocking Sound
by abs | March 24, 2019, 05:46:28 PM
Thanks all for the replies.  I've been running 5w-30 full sy...
Re: 15 SHO F/R Brake Torque Specs
by SHODOWN | March 24, 2019, 12:17:38 PM
Nick thank you so much this is awesome...great addition to the GT info...
Re: Gearhead E30 vs Livernois E30 MIR 03/17/2019
by sm105k | March 23, 2019, 10:49:00 PM
Last I heard, as of a few days ago, all IC's on hand have been so...
Re: Tune for 2019 Flex
by Zxtman | March 23, 2019, 06:18:32 PM
Thanks for the feedback guys.  I now see I have a couple of optio...
Re: BENDIX & WAGNER Rotors!
by ZSHO | March 23, 2019, 01:44:12 PM
Brake Pad “Break in procedure for “Severe Duty” vehicles” Bulletin BPI...
Re: OEM Brake Endurance
by FoMoCoSHO | March 23, 2019, 11:35:01 AM
No worries......2010 to 2012 GEN42013 to current GEN5 The EBC's w...
Re: New member from Massachusetts
by 18SHO | March 23, 2019, 07:26:31 AM
  Hello everyone!!. I've been a long time owner of the SHO ...
Re: Articles on Engine Design
by SHOdded | March 23, 2019, 05:38:05 AM
Vehicle Miles Traveled vs VOC Emissions TLThttps://www.ecoboostperform...
Re: Struts going bad...Suggestions?
by Sabtaj1 | March 23, 2019, 02:10:42 AM
Are you sure its the struts?  Say if you are driving over 40mph a...
Re: Going Back to the 1/4!
by ajpturbo | March 22, 2019, 04:33:08 PM
Nice Job! 81 degrees in FLorida and almost 110mph on a 93 tune is not ...
Back to top
