- RotM Winner
- Sr. Member
- Logged
Quote from: Macgyver on December 18, 2018, 07:19:18 PM
First I want to say thanks for AJP for working with me on this project. He did a great job developing an alternative non blending fuel for the SHO/Ecoboost.
I had a Sheetz built within a mile of my house. If anyone is from Pa here. Sheetz has pretty very good fuel. Their E85 us usually top notch and presently $1.99 a gallon. I do want to say tho On the 93 side. I use Sunoco Ultra which again I happen to be lucky and have a tank farm just a few miles away. I am blessed by great fuel according to AJP.
Second. This is NOT a "Send it tune" or "Go fast tune". This is not a racing E85 tune. So lets keep the thread where it should be. E85 and having a different way to fill your tank without blending. Its an alternative fuel tune for the Ecoboost that should save you money. Not get more miles per tank or go faster than whatever fuel or tune.
AJP has the tune. Its for Full E85 out of the gas pump (Sheetz in my case). Sheetz states their pumps can vary from E50 to E83. In the summer. We had E90 near me according to a few guys testing kits. I was running E30+ as I tend to mix a on the high side. With AJP tunes. I had no fuel pressure issues at all. Moving on.
Now for the tune. Its Conservative. AJP said it's at 10psi boost and Mid 20's + on the spark. Plus robust/rich fueling. AJP said the lowest she got on the pressure was 1500psi ? No retarding at all from the logs he has gotten. Today I data logged it at around 35-37deg outside temp. She should be faster than stock according to AJP. I have no way of knowing and will make no claims except that AJP's E30 tune blows this out of the water. Haha.
Now the ONLY caveat. Cold starting. AJP made some adjustments. Its just an E85 thing. Last week I started her around 30deg with an over night low of 17. She sits outside in the shade. No garage. She takes a little longer to turn over compared to regular fuel starts. Once warmed up/started once. No difference at all. Today I started her after sitting for 4 days. I had Carpal tunnel release on Friday morning and should not drive. She started fine as in the normal E85 first cold start start up.
Oh yeah. Your tail pipe tips stay clean and she smells wonderful on idle.
Is this with stock HPFP?
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89 fastest ET
