Ok i will do a datalog shortly.Also, when i step on the gas, there is a noise coming from the passenger side turbo that sounds like an exhaust leak, however, there are no leaks and the pipes are installed and tensioned correctly. it is not loud but you can definitely notice it.Is this common? and possibly something to do with this issue?
AJP - The boost felt the same before the DYNO tune attempt as it did afterwards. So it was low even when i had the 5-Star tune on it. I never had 5-Star retune it after i put the 35" x 12.5 tires on it (which were installed only 2 months ago- about 1 year after i had it tuned for 33" tires), that may have effected it??I am taking it back to the speed shop for a road test tomorrow to see if they can sort this out. I will get the necessary files off them then.ZSHO - i will do just that right away.
