September 24, 2023, 07:12:50 PM
Author Topic:  315s?  (Read 4906 times)
Offline Katnexp
  • Jr. Member
  • HouTex
  • -Given: 9
  • -Received: 2
  • Econoob
  • Liked:
  • Likes Given: 0
315s?
« on: November 17, 2018, 06:36:36 PM »
Does anyone think I could fit a 20x10/10.5 with a 315 on the back of my exp sport? I’m gonna have to something new cause my wheels and tires are trashed. Thanks.
2014 Explorer Sport. NGK plugs, 170 degree thermostat, 3 bar, MDesign intake, EPP Hot Pipes, TiAL bov, Livernois catted DPs, 3rd cat delete, Borla S-Type with Magnaflow X resonator, Unleashed 93 tune, AJPTurbo tune, H&R springs, TRS Morimoto hid and led fog kit
Offline Sabtaj1
  • Full Member
  • Quad Cities
  • -Given: 33
  • -Received: 93
  • MANIVAN
  • Liked:
  • Likes Given: 0
Re: 315s?
« Reply #1 on: November 18, 2018, 05:45:24 AM »
Don’t know of anyone that has tried it.  I ran 20x8.5 with 275/40 fronts and 20x10 with 315/35 on my flex without any issues. Think offset was 35 for fronts and 42 for rears. Hope that helps a little.
13 Eco flex.
Stainless works non cat DP/ MRT axle back/ Airaid cai/ 170 T-stat/ 3 bar map/ 1 step colder plugs/ snow stage 3/ hot pipes w/TIAL BOV/ torrie tuned-SCT/
Offline ToMang07
  • Full Member
  • Maine
  • -Given: 59
  • -Received: 76
  • FoSHO
  • Liked:
  • Likes Given: 0
Re: 315s?
« Reply #2 on: November 18, 2018, 08:07:27 AM »
I imagine they would, I ran 295s on my taurus, Just need the right wheels/offset.
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
Offline Katnexp
  • Jr. Member
  • HouTex
  • -Given: 9
  • -Received: 2
  • Econoob
  • Liked:
  • Likes Given: 0
Re: 315s?
« Reply #3 on: November 18, 2018, 08:14:33 PM »
Thanks for the input guys. I did some reading around and even though both a 315/35/20 and 275/40/20 are the exact same overall diameter, I’m not sure if I should chance running different sizes for fear of breaking something with the awd unit. Especially if I’m gonna be running the truck hard off the line from time to time. Btw here’s what I’m planning on getting...
Offline Sabtaj1
  • Full Member
  • Quad Cities
  • -Given: 33
  • -Received: 93
  • MANIVAN
  • Liked:
  • Likes Given: 0
Re: 315s?
« Reply #4 on: November 19, 2018, 03:38:07 AM »
I never had any issues with the AWD unit running my set up.  Actually went 12.14 in my flex with that set up and consistent 12.20's without having any issues.  ran that set up for a couple years.  Just cant rotate the tires, so keep that in mind.
13 Eco flex.
Offline fsttyms1
  • Newbie
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
Re: 315s?
« Reply #5 on: August 04, 2023, 03:40:50 PM »
I know this is an old post but i ran the staggered setup for 2 years with zero issue, then moved up to 20x10 +40  on the front as well to run 315s on the front. they dont stick out or rub
* Recent Topics
Re: My Staggered, TSW Wheel Setup.....
by dillrepair | September 23, 2023, 08:51:58 PM
Just wanted to say thanks to bpdHave the same setup bc of seeing this ...
Re: Body kits
by MKSJUNKIE | September 12, 2023, 10:23:45 PM
Sounds good I appreciate it. I...
Re: PTU Upgrade - Dorman
by BlueSHO | September 11, 2023, 10:46:17 AM
@timbo anything?Sent from my SM-G781V using Tapatalk...
Re: 2012 SHO PP
by bpd1151 | September 01, 2023, 08:25:20 PM
Pics are always helpful..... I mean c'mon now..... who doesn'...
Re: Fuel injector coding
by SHOdded | August 15, 2023, 01:38:53 PM
i would say to try new injectors then since fuel pump operation is goo...
Re: 315s?
by fsttyms1 | August 04, 2023, 03:40:50 PM
Thanks for the input guys. I did some reading around and even though b...
by kryptto | August 02, 2023, 09:12:14 PM
Just a quick update.....Went and visited the shop yesterday (07/21/202...
LH (Driver Side) Halfshaft Removal Tips?
by DaveBey | July 29, 2023, 09:54:27 PM
Does anyone have any tips for removing the LH (driver side) halfshaft?...
Re: New block, low oil pressure
by SHOdded | July 26, 2023, 01:56:20 PM
do you have an sho block or one from an explorer? their setups are sli...
Re: MSD Coils on 75% Sale
by SHOdded | July 26, 2023, 10:41:09 AM
feels like a closeout ... once gone, gone....
