2014 Ecoboost No Crank No Start
Started by ToMang07, November 11, 2018, 02:53:40 PM
Have you had work done at this dealership before?  Dealt with the management?
ToMang07
Quote from: SHOdded on November 23, 2018, 05:10:43 PM
It's where the truck was purchased, only time it's been in was to investigate an intermittently not working horn and a coolant flush. (Unknown whether it's related, however they are aware of it.) Tranny flush was done elsewhere.  Other than that, nothing has been done to it besides brakes, oil changes, and an Intake. 137k miles.
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
ToMang07
So after 2 and a half weeks...
It was a couple "broken" wires. What I suspected from the start, which Ford claimed they checked.
Not a good sign that a 4yo harness is having issues already.
~Tom~
Did they identify the specific wires.  Yes occasionally there are wiring issues on Gen 5, not often tho.
I could certainly relate as the waiting game is sometimes exhausting! Maybe its a pigtail harness connector! Best of luck on a permanent viable fix. Z
ToMang07
Quote from: SHOdded on November 28, 2018, 04:20:00 PM
The only info they gave was that it was the "Main harness that goes to the in-cab fuse block." I tried asking more questions but they basically said the tech wasn't there and that's all they knew.
~Tom~
Ok so some wire between the BJB and the BCM.  Aside from power, not sure what other connection there is.
