- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: Macgyver on November 03, 2018, 02:29:05 AM
Quote from: TopherSho on November 02, 2018, 09:33:11 PM
Quote from: shoNoff on November 02, 2018, 06:43:04 PM
If I come out hard say launch around 2400 or so and get any sort of wheel hop the car hits the rev limiter or hesitates to shift. You can see if you watch the video any pass I make in the 12.8's right after the 60 foot you can see the nose dip down. To me it's almost like something in the drivetrain is holding the car back from breaking itself. Sometimes it's not even a limiter hit. Just the nose will dip quickly then the car will shift. Last Friday it happened to me up there and the car was smashing the limiter in first. I thought I broke the transmission. So I eased her down the track to a 17.4 or something.
you are nearly perfectly describing low tranny fluid. with my car, if the tranny oil is not above the checker-marks and almost covering the dip-ball... my tranny FREAKS out stalls, dropps power then shifts into 3rd or 4th and stalls.
i would check your tranny oil... it is VERY command for many members here to have to add 1/2 a quart more once the power gets above 500fllbs..
I am having this issue and I have added the extra Trans Fluid long before I got an Etune from Brad. I think we need to shift sooner from 1st to 2nd then stretch out shifts 2-3 and shifts 3-4 to max RPM capable shift point
Makes sense. In my car, I thought it was due to wheel spin. 1st...spinning...catch some traction...top of first...spin again...catch..then into 2nd. Something like that. Wish I had this thing on a dyno to see where power is at. The Continental ExtremeContact DW tires I have are really good...but with the power...and track prep being hit or miss..i think a better tire is needed. With better traction I think diagnosis will be more accurate if this issue persists.
