Boost leak
Started by arrivalblue, October 12, 2018, 11:52:06 PM
Motorcraft SynBlend or Full Synthetic?  SynBlend can be as low as 5% actual synthetic base stock, so for just a little more, going full synthetic is well worth it.  And there are MANY quality choices of affordable full synthetics available either in store or online.  Pennzoil, Mobil, even Valvoline have rebates going on some of the time so be sure to check for them too!
arrivalblue
I'll have to just switch to Mobil 1 full synthetic. I use the motorcraft blend they recommend. At 84k miles is it gonna mess anything up? Gonna do some logs tonight I'll post them up see if maybe you guys can see something I can't? Idk how to read them that well
SM105K
Quote from: arrivalblue on October 16, 2018, 04:34:27 PM
You will be fine.  I get 6 quarts of Mobil 1 Full Syn and either a Motorcraft or Mobil 1 filter for literally 36 bucks.  I change my oil and oil filter every 3 thousand miles because it is so cheap.
arrivalblue
Yea the cost isn't the concern lol. Like I said I use it in other cars I own just saw big name tuners even recommending motorcraft for these cars so just stuck with it. I'd rather be on Mobil 1. My Cobalt SS/SC has lasted 265k miles mobil 1 I give credit to. Car always sees full boost lol
I would also check the PCV -Oil Sep!  Any Signs of smoke through the tailpipe!  Need to stay on Top of your maintenance aspect especially when tuned or prior too.  Z
arrivalblue
Nope only when cold! That's what's driving me nuts. It's nothing obvious lol
arrivalblue
Few Logs If you guys are interested and see anything I cant?
arrivalblue
#37
Seeing 0 for wastegate percentage in my logs. So that's showing solenoid isn't even trying to make boost? Maybe it's sticking?
Very well could be stuck.  Just strange both are in bad shape and still no codes, underboost or overboost ...
arrivalblue
I was thinking maybe it's just the single boost solenoid. We will see later today lol. For the cost I'll just change it
I think you can try to blow on the solenoid to see if its restricted!
Need to verify it's getting the proper voltage and inspect for any loose or corroded connector coming from the solenoid......
I was able to access and paste one of the PDF! I hope this helps any.  Z
PDF Below for reference....
Turbocharger/Supercharger Boost Sensor A Circuit Range/Performance
Description
This DTC sets when the TCBP PID does not correlate with the BARO or the MAP PID.
Possible Causes
Damaged turbocharger boost pressure (TCBP)/charge air cooler temperature (CACT) sensor Contaminated or blocked TCBP/CACT sensor Slow responding TCBP/CACT sensor
Diagnostic Aids
Check the intake air system for leaks and restrictions.
The TCBP/CACT sensor is a dual function pressure and temperature sensor located on the intake air tube between the charge air cooler (CAC) and the throttle body.
Action
GO to Pinpoint Test EA
This pinpoint test is intended to diagnose the following: intake air temperature (IAT) sensor (12A697) turbocharger boost pressure ( TCBP )/charge air cooler temperature ( CACT) sensor (9F479) manifold absolute pressure ( MAP )/intake air temperature 2 ( IAT2) sensor (9F479) powertrain control module (PCM) (12A650).
https://drive.google.com/file/d/0B8JUL90DXgdidFg4ZmN6SzF3cVVueGo2TFNSNUtfamJPcllN/view?usp=drivesdk
arrivalblue
Did another pull on lunch today the wastegate percentage was 79-80 instead of 0 like pulls yesterday. Strange.... makes me think everything is good until warms up then either maybe a wastegate or the solenoid starts to stick a little. Off to see if can find one! And thanks! I'll try to inspect and clean them all!
maybe just pull the solenoid, check for contamination of the connectors as well.  Anything but vacuum in vacuum lines is never good :)
arrivalblue
#44
Yea that's the plan here in about 20 minutes plus remove and spray all the sensors with cleaner. Dealership said they would flash it with tune may sort out issues..... lol I'll wait to fix them first. Attached is a log with car wanting to build boost from today.... frustrating lol
