- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: StinkinLinkin13 on September 24, 2018, 08:24:54 PM
Kinda late but this is how I ended up solving my transmission overtemp condition.
Tru-Cool - Max LPD47391 Low Pressure Drop Transmission Oil Cooler.
OEM Trans T-Stat delete.
Equaled a MAX Temp of 170-175° no matter how hard I pushed it even in the 100+ air temps here in SATX.
Having said that... The OEM aux trans cooler would be much easier to install. Much smaller tho and not quite as effective in my research.
Sick! I love it!
