Smoking from bad turbo
Started by Spyder3000gtvr4, September 06, 2018, 03:50:44 PM
ToMang07
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
Spyder3000gtvr4
i was in high hopes that after reading the article that my synthetic oil was affecting the phasers enough to throw 147 codes at once. Lol ok new oil being added to my list for timing chain.
Kik: Spyder3000gtvr4
Got my Sho deciding to make it a DD or use it for my tube chassis build :)
Its very unfortunate but its conventional oil that does more harm than good,especially when changed @ high intervals,which ultimately will leave you having to change your VCT solenoids sooner than later.  Z
Spyder3000gtvr4
Pw495? Motorcraft waterpump, pitting my ordertogether now and finding a few different part numbers
Spyder3000gtvr4
I ran the vin on the site and the site says pw538, uhg why is there 43 different waterpump numbers!?!?
I dunno.  Besides actual differences in one sprocket vs two etc.  Maybe updated seals?  No idea.  go with the part number it shows you for the MY engine you have.
Spyder3000gtvr4
I'm pretty sure that's what the guy was talking about on the other forum about upgrading the newer style. Single sprocket like an old school bike chain vs what looks like 3 bike chains compressed into 1, great description I know. I'd rather do the newer style chain that isn't notorious for stretching. All I ordered so far was cam locks and head temp sensor. I'm pretty sure that since I'm replacing the chain and water pump all that's left is the phasers which I was considering changing anyway before you said I don't really need them. The vct solenoids you said 1 for each Bank I take that means 2?
are you referring to the ford flex forum link posted earlier?
yes, 2 vct solenoids in all for the SHO.
Spyder3000gtvr4
Don't be.  I finally went through that thread, lot of good info in there, just not sure how much of it applies to the SHO.  Have to compare at some point ...
Spyder3000gtvr4
Well I reached out to livernous tonsee if they could give me a 100% answer the chain thing. To make it worse I reached out to two vendors to possibly order the pw538 waterpump and 1 said yes and 1 said no. Uhg.
Cam locks, 2 vct sensors, engine block sensor... ordered.
Timing cover gasket set? Guess so right?
So mystery waterpump and chain left to order still
timng cover gasket is fabricated from RTV, so you have to buy RTV.
Spyder3000gtvr4
Well the "kit" on rockauto has a tube. Not sure what the other stuff is 1 looks like the waterpump gasket.
