Best Electric Cutout - All This Exhaust Talk Has got me thinking...!
Started by irondoor19, September 01, 2018, 12:10:50 PM
BoostfoSHO
https://youtu.be/JySTBbD416Y
Quote from: 802SHO on September 04, 2018, 07:25:37 AM
Quote from: BoostfoSHO on September 03, 2018, 09:40:33 PM
I have electric cutouts and I love them. Keeps the car factory quiet or really loud depending on your mood. I placed mine after an x Pipe right after my catless downpipes, removed the 3rd cat and muffler to make space. Then I programmed the remote control to the garage opener and that's that.
That's sweet!  I think you made a video of this yes?  Got to admit choosing wide open or quite is pretty sssslick
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
802SHO
My exhaust is going to sound like your cut outs stuck open lolol
TimmyATL
I have LoudValves boost activated cut outs that are installed just after the X portion of my Corsa exhaust. I have them on a manual boost controller set to 8psi. They do rattle at about 2500rpm but what cutouts don't lol. I have had no concerns with them so far and have been on for 2 years. Sorry not able to post from my phone to this web sight for pictures and video.
13 SHO PP, Airaid intake, 170 T-stat, 3bar map sensor, Ecopower Parts hot side pipes, Turbosmart 7lb wastegate actuators, Stainless Works catted downpipes, Corsa cat back exhaust with Loudvalves exhaust dumps, Alky Control Meth Injection, LMS Dyno Meth tune. TSW Nurburgring  with NItto NTO5
What error are you getting, Tim, posting pics & vids?  If they are not too large, they should upload just fine, tho longer videos are suggested to be hosted elsewhere.
TimmyATL
I do not have taptalk nor do I have the needed pics and videos on my work PC.
802SHO
Quote from: TimmyATL on September 04, 2018, 03:31:13 PM
Performance wise your car is faster with the cutouts than before yes?
TimmyATL
I did not do a closed vs open runs to see if I gained or loss power.
