Lift kit for my Truck
Started by orangehues, August 31, 2018, 09:35:41 AM
orangehues
2012 Ford F-150 Lariat SUPERCREW.. Need some advice. I would like to add an extra 4-inch of ground clearance on my truck. What brand of suspension lift kit should I go for?
ToMang07
You looking for cheap or plush ride? A budget would be a good start.
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
802SHO
