Power loss at mid and high rpm
Started by Quinid, August 14, 2018, 04:09:24 PM
Quinid
Quote from: ToMang07 on August 14, 2018, 06:19:59 PM
Quote from: Quinid on August 14, 2018, 06:09:56 PM
Oil changed about 1500 miles ago. Doubt the plugs have been touched. Unless they check the plugs when Ford does the Ford certified thing, which was done at 21k miles. I'll try a KAM reset. Ty Hopefully not cats. Found out the hard way Ford warranty does not cover exhaust with the taurus.
QuoteThe warranty coverage period for:
• Passenger cars, light duty trucks (applies to vehicles up to 8,500
pounds GVWR)
— The emission warranty coverage period is 8 years or 80,000 miles
(whichever occurs first) for catalytic converters, electronic
emission control units, and onboard emissions diagnostic devices.
Page 23 actual, 18 in document.
https://www.ford.com/resources/ford/general/pdf/brochures/14frdwa2e.pdf
Well that would explain it. The taurus had over 80k when the cat went out. But they covered the bad injector that caused the cat to go bad.
2014 Blue Flex 303A Appearance package all stock
2000 F250 XLT 7.3L 410k miles
SOLD--2010 nonPP SHO  Unleashed 93 tune, 3 bar map, K&N drop in filter. PPE Catted Downpipes. VTA mod
1957 Chevy 3200 pickup 3 speed stock straight 6
1968 Camaro RS 3 speed 350 sb with vortec heads.
Quinid
They called again today. The mechanic is claiming a bad EGR tube is causing it. They will try to replace it today before I'm off work.
EGR tube?  Would love to know where that is on these engines!
Quote from: SHOdded on August 30, 2018, 04:09:34 PM
Funny I was thinking the same...EGR generally is handled via cam timing strategies now...quin ask them where that tube is because there is not on that goes from the exhaust to intake anymore
Quinid
#19
I will when I pick it up tomorrow afternoon.
They replaced it and claims it's running great now. They are just waiting on the door hinge to come in to fix the driver door ajar alarm.
Quinid
This is confusing... So the mechanic calls it a EGR tube. The front desk lady said it's a wastegate solenoid and the manager called it an emissions tube and claims Ford calls it a EGR tube.
Bill: Performed EEC found code P0234, Performed PPT HN1-Y, HN2-Y visual concern, vacuum supply - vacuum hose swelled out
Correction/action taken
Removed and replaced hose, cleared code and retested to verify correction
Part: AA5Z9E499A
https://parts.levittownfordparts.com/oem-parts/ford-connector-tube-aa5z9e499a/
#15 in illustration
Referenced as a vacuum tube, I suppose it works as a pseudo EGR tube :D  $4 part causing all these headaches?  SMH.
SO essentially its only a wategate hose!
The hose swelled out due to Ford NOT installing a hose clamp from the factory!!!  Z
Quinid
Must have been it, cuz it runs great again.
They fixed it right, then, and that's what matters.  Enjoy!
0mn1p0tent
#25
2013 Fusion SE 2.0L Code P0234 Overboost condition.
The solution for my vehicle was a wastegate solenoid assembly (CJ5Z-9K378-B) which includes replacement hoses and the clamps.
NOTE DO NOT BUY just the Solenoid Ford part (CJ5Z-9K378-A) which is $20 cheaper.   While they look almost exactly the same, the electric connector is different and it will not fit.   How do I know this?  I am insanely cheap.  This time my frugal nature cost me an additional trip to the parts store for an exchange.
Learn from my error.   You're welcome!
45 min hour install.   20 of that was just finding the location of the part as I did not have a manual.   :P
Let the car cool completely.
Ramp or jack the vehicle.
Remove the debris shield.
From underneath the vehicle look for the part on the back of the engine, passenger side, near the turbocharger.
Remove the electrical connector, three hoses/clamps.
The part is mounted on a small bracket with a detent to keep it in place.  Wiggle it back and forth to get it off the bracket.
Reverse the process to install the replacement.
I have seen people quote $300 for diag and installation of this part.  This was not at all a difficult job at all.   Good place to start.
I guess its a personal preference but in the OP case there was no need to replace the whole assembly and instead you only need to replace the 1/4 wastegate hose which is a simple plug & play install located on TOP of the manifold.  Z
