Wheel AR92429012735 Specs and Dimensions:
- Size: 20" x 9"
- Lugs: 5 x 114.3mm (5 x 4.5")
- Finish: Satin Black
- Backspacing: 6.38"
- Offset: +35mm
- Construction: Flow Formed Aluminum
- Center Bore: 72.60mm
- Center Caps: Included
Center bore is larger than for the SHO, the SHO is 63.4, will need adapters I think. The offset should work fine, may be a tiny bit much depending on how tucked in or flush you want the wheel etc. Backspacing is likely fine as well.
