def PTU and intercooler. But also regular checks for pooling oil in the turbo tract. Might want to replace the PCV Valve assembly also as it is available as a separate part. Use only a quality, low volatility full synthetic engine oil, especially if you see anything more than misting in the tract at any time. While it is not a "fix", it at least is a major assist. A catchcan from JLT or RXP might also be on the table in that case.
