2010 Taurus SHO TT Replacement in Garage
Started by SierraTBD, July 30, 2018, 11:17:21 AM
SierraTBD
I'm very confident I can replace both turbos in my garage but just wanted some encouragement (hopefully). I know the rear sub-frame will need to be lowered slightly if I can't find patience. What else should I expect? Thank you and much appreciated!
geophb
I cant comment on the rear turbo but I did the front one. simple hand tools. I pulled bumper, fans, rad/intercooler(comes out as one) then there was all kinds of room -> way easier than it sounds lol. But you may only need to pull fans. Don't over bend the flex joint on the downpipes cuz they will break.
New turbo did not have mounting brackets, updated design?. seems like alot of stress on a sheet metal manifold?
2010 Taurus SHO 3bar AJPturbo tune
StealBlueSho
Quote from: geophb on July 30, 2018, 11:58:16 AM
Yes, they updated the design and the newer turbos don't have mouting brackets... the cast iron manifolds will hold them fine.
geophb
Quote from: StealBlueSho on July 30, 2018, 12:16:27 PM
I honestly don't think there cast, which is why i was wondering. It looked like sheetmetal to me
When I replaced my ptu it also called to lower the sub frame for removal.
I just removed the lower front engine
Mount(dog bone ) and used a ratchet strap to pull the engine forward towards the radiator.
This is the bracket, you can see the bolt compared to where it's supposed to mount.
StealBlueSho
Quote from: SHOdded on July 30, 2018, 02:16:49 PM
Throwdown with Mike K.  Now playing.
Negative...they feel like cast iron to me so I just assumed they were along with the rough exterior and rusting... but I defer to Mikes post.. Stainless Steel/Steel it is... lol
You know what they say when one ASSumes there BJ.
LOL. ****Snickers.
Love you dumpling.
6500rpm
Sooo, are there two different exhaust manifold designs? I seem to recall some reports of the inner wall on the design that Mike has pictured may be prone to degrading/flaking and taking the turbo's out. If that's true it might be worth taking a good look any time you're in that area of the engine.
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes,3 bar, Gearhead AO tuned!
SierraTBD
First of all, thank you to everyone who replied :notworthy:  I am new to the Ecoboost world coming from the diesel community. Belonging to DieselPlace.com I certainly appreciate the wisdom that exists in members of forums like this one.
Sounds like the rear does not need much more clearance to be removed.
StealBlueSho
Quote from: bpd1151 on July 30, 2018, 04:56:10 PM
LOL. ****Snickers.
Love you dumpling.
Ha! Just to throw some oil in the mix (can't make dumplings without it) this article... which is fantastic also had LME calling out the manifolds as cast-iron....
https://www.fordnxt.com/tech-stories/engine/ecoboost-build-600-plus-horsepower-from-a-livernois-built-3-5-v6/
Wonder if that is your motor in the article?
StealBlueSho
Quote from: SierraTBD on July 30, 2018, 09:13:58 PM
The front is reported as easy. The rear is a PIA from those that have done it from a creeper...
Quote from: StealBlueSho on July 30, 2018, 10:57:07 PM
This would be correct in an F150 application.  Their manifolds are different from the transverse applications.
https://www.brewcityboost.com/wp-content/uploads/2017/08/crp-manifolds-2011-2012.pdf
SierraTBD
Quote from: StealBlueSho on July 30, 2018, 10:58:17 PM
A PIA for sure but definitely still doable right?
