I have a couple posts on here already, but I will be having a used engine installed in my MKT in the next couple weeks. I already plan on replacing the timing chain, guides, and the water pump. Looking into rebuilding the turbos or replacing outright as well.
What else should I look at replacing before the new/used engine is installed? Was thinking alternator as that looks like it'll be a pain to get to as well, along with the accessory belt and tensioner.
Thank you for any help or suggestions!
