Stock Turbo Mounting Stud Size
Started by autobahn terror, July 12, 2018, 06:58:00 AM
irondoor19
Quote from: autobahn terror on July 19, 2018, 09:35:13 AM
They are indeed. Some of the stuff came into today. The Graph-Flex Gasket Sheets 67006 is really nice material. Thick as a clipboard too. Once the rest comes in, that leak is going to be gone for good...
WTF: Long Time No hear, How did the CF drive shaft Turn Out....?
autobahn terror
The short story is it didnt. The driveshaft shop started on fabricating the custom mounting plates and such, when they said they were ready to spin a shaft, I triple checked my measurements and then took a piece of 3" exhaust pipe to check clearance and found that it would not clear the tunnel at the angle it would need to be at being one piece. They planned on spinning a 3.8" diameter shaft so if 3" looks like it would rub 3.8 likely would even bolt in. I asked them about changing the plan up to build a stronger two piece with a poly carrier bearing from kerbid , (They make upgraded bearings for the CTS-V), and the guy I was in contact with started going off on some tangent how they wouldnt work with another shop to make a shaft that would fit. They haven't responded to my last few emails so I just wrote them off. I bought a used shaft for a hundred bucks and had it sent to kerbid so they can make a poly-carrier bearing for it. For what its worth, Kerbid looked over the stock shaft and said the only weak points on it are the carrier bearing and the U joint. The shaft itself fine for performance applications within reason.
2014 PP, Dicunzolo Gen2 Mounts, Gear Head Intercooler, EcoPowerParts Charge Pipes w/Meth Bung @1GPH, Hennessy KnN CAI W/RECIRC, Alky controls meth injection, Lightly Ported Intake drilled and tapped for Port Meth Injection 1GPH per Cylinder, XDI EVO HPFP, Deathwerks 340LPH intank LPFP, ATP Turbos, EPP Catless DownPipes, Corsa CAT Back, 160TSTAT, 3BAR MAP, Stock Ignition coils, SP542 plugs .028, UPR Catch Can, MEGAN Coilovers,  Power Stop Z23 Brake Kit, 93octane Dynotune @ 430AWHP/430AWTQ...Soon to be much more
irondoor19
#18
That is Great, Will be contacting them Strait Away...thanks
I did, and when they Get it Figured Out,
I am IN, Group buy Anyone...?
autobahn terror
UPDATE:
THIS GASKET MATERIAL IS GREAT, IF YOU CAN ACTUALLY CUT AND SHAPE IT WITHOUT DESTROYING IT!!!
so with that said, Here's what happened... I finally got the car on a lift last week to rectify my leak, and to my surprise the leak was NOT where I figured it was, turns out it was at the Turbo to Down Pipe Gasket, NOT the turbo to Manifold side. Which sucks cause I bought every thing for the other side where I figured the issue was because that where its was last time. It also turns out that one of my Studs, (this time on the other side of the turbo), came out with the nut as I was disconnecting the DP, and while taking the nut off it stripped/flattened a piece of the thread with it. I tried a thread repair kit on it and it kinda came back, but now I need new studs for the Outlet of the turbo. And of Course I cant find the correct P/N again. I dunno how Z found it definitively but he is the man for doing so...Z HOW did you find that P/N last time?
The leak ended up being the DP to Turbo being loose with gasket burnt up. I could replace the gasket with something I didnt have so I flattened and reused what I had with some of the Permatex liquid gasket sealer I had and so far its holding, but I suspect not for long. I DO NOT RECOMMEND ATTEMPTING THE GASKET SHEET MATERIAL FOR THAT LOCATION; if there is a problem It could blow some material into your CATS...
Quote from: autobahn terror on August 24, 2018, 10:39:25 AM
UPDATE:
@ Parts Dept shelf!  Glad to be of some assistance brother .Z
