Started by StealBlueSho, July 08, 2018, 10:52:40 AM
Quote from: J-Will on July 09, 2018, 12:17:07 PMwhere in northern VA are you getting E blends?
Quote from: mrhighcaliber on July 09, 2018, 04:41:45 PMPreturbo meth injection works wonders for this. I didn't get a chance to datalog for gearhead tuning (new sct from them is in the mail) before my Sho's total loss collision, but with meth on a 75-85 degree day, I was seeing wot iat's climb from 118 up to 140 13-14psi target with post cac meth alone. With post cac meth and pre turbo meth I would see max 130. I'm plotting on a 2013-15 and I will run the same setup. Meth +hpfp upgrade provides great power and max safety. Adding pre turbo meth nozzles and or upgraded turbos with provide imho, a parallel increase in power and safety. Sent from my PH-1 using Tapatalk
Quote from: StealBlueSho on July 09, 2018, 04:43:40 PMQuote from: J-Will on July 09, 2018, 12:17:07 PMwhere in northern VA are you getting E blends?There is an E85 pump at the Sheetz in Manassas by the Costco and another one at the Raceway Gas station in Opal across from the Clarkbrothers shooting range.Sent from my iPhone using Tapatalk
Quote from: J-Will on July 16, 2018, 07:58:32 PMQuote from: StealBlueSho on July 09, 2018, 04:43:40 PMQuote from: J-Will on July 09, 2018, 12:17:07 PMwhere in northern VA are you getting E blends?There is an E85 pump at the Sheetz in Manassas by the Costco and another one at the Raceway Gas station in Opal across from the Clarkbrothers shooting range.Sent from my iPhone using TapatalkI looked up the e85 pump location using the DoE site, and was pleasently surprised to see so many more stations that have e85 in northern VA. This has to have significantly changed from about 6mo ago! Thanks for the heads upAlso, keep us updated on the GH CAC. Monitoring all of these sites and Facebook groups is too much of a chore. We ate too fragmented. Sent from my Pixel 2 XL using Tapatalk
Quote from: StealBlueSho on July 16, 2018, 08:00:39 PMQuote from: J-Will on July 16, 2018, 07:58:32 PMQuote from: StealBlueSho on July 09, 2018, 04:43:40 PMQuote from: J-Will on July 09, 2018, 12:17:07 PMwhere in northern VA are you getting E blends?There is an E85 pump at the Sheetz in Manassas by the Costco and another one at the Raceway Gas station in Opal across from the Clarkbrothers shooting range.Sent from my iPhone using TapatalkI looked up the e85 pump location using the DoE site, and was pleasently surprised to see so many more stations that have e85 in northern VA. This has to have significantly changed from about 6mo ago! Thanks for the heads upAlso, keep us updated on the GH CAC. Monitoring all of these sites and Facebook groups is too much of a chore. We ate too fragmented. Sent from my Pixel 2 XL using TapatalkCareful with that site... lots of "E85" stations that are just E10.Sent from my iPhone using Tapatalk
