P0218 Transmission Over Temp Condition
Started by StinkinLinkin13, June 22, 2018, 10:57:04 AM
StinkinLinkin13
#15
So taking advice on a trans cooler. The OEM PP/police external style vs the Hayden 679 stacked plate cooler which seems to be larger. Any experience, advice suggestions?
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
irondoor19
Quote from: StinkinLinkin13 on June 23, 2018, 07:08:25 PM
TO START OFF:
https://www.ecoboostperformanceforum.com/index.php/topic,522.0.html
a good primer, and then:
http://www.ecoboostperformanceforum.com/index.php?topic=5389.0
and finally:
https://www.ecoboostperformanceforum.com/index.php/topic,6585.0.html
We Did the First One to a Tee, I wish We would have Done it a tiny bit different
NOW U are Fully Informed...?
StinkinLinkin13
#17
Cool. I had read the first and the third threads you listed. Never saw the second one. Good info. I wonder how hot guys transmissions are running and they may not even know it. I had confidence in the stock setup but when I started having the limp mode and the DTC till I became interested in my trans temp. I'm pretty sure guys with the LVN V11 tune and the condenser/trans cooler ONLY are running higher temps than they assume at least in higher temp areas like myself. Especially if you have a lead foot like me.
StinkinLinkin13
#18
Kinda late but this is how I ended up solving my transmission overtemp condition.
Tru-Cool - Max LPD47391 Low Pressure Drop Transmission Oil Cooler.
OEM Trans T-Stat delete.
Equaled a MAX Temp of 170-175° no matter how hard I pushed it even in the 100+ air temps here in SATX.
Having said that... The OEM aux trans cooler would be much easier to install. Much smaller tho and not quite as effective in my research.
802SHO
Quote from: StinkinLinkin13 on September 24, 2018, 08:24:54 PM
Sick!  I love it!
