Cam sensor Change
Started by jay.denning73, June 17, 2018, 02:10:50 PM
jay.denning73
Does anyone have the cam sensor part number? Bank 2 if it matters.
Does anyone know how hard it is to change? I think I may be able to manage from the wheelchair if it slides in and out.
TIA,
  Jay
StealBlueSho
Not sure the part number... but you need to pull the valve cover off to replace it. It's kind of a PIA.
better bank 2 than bank 1 LOL, but yeah ...
10   BL3Z-6B288-C   Camshaft Position Sensor
TAURUS; 3.5L; W/ TURBO
$12.82   $8.11
Just 1 cent more than a spark plug!
jay.denning73
Is there a video somewhere? Looks like it should just unbolt slide out and slide in?
What am I missing?
TIA
    Jay
Sent from my SM-G955U using Tapatalk
Removal and Installation
Both sensors
Remove the ACL outlet pipe and the ACL . Refer to Section 303-12 .
RH sensor
Position the RH turbocharger intake tube aside. Refer to Section 303-12 .
LH sensor
Position the LH turbocharger intake tube aside. Refer to Section 303-12 .
Both sensors
Disconnect the CMP sensor electrical connector.
Remove the bolt and the CMP sensor.
To install, tighten to 10 Nm (89 lb-in).
NOTE: Lubricate the CMP sensor O-ring seal with clean engine oil.
To install, reverse the removal procedure.
LH = Bank 1, RH = Bank 2
jay.denning73
Quote from: StealBlueSho on June 17, 2018, 04:15:15 PM
It does not seem like the valve cover needs removed for this?
Nope no need.  For vct solenoids, yes.
jay.denning73
Cool thanks.
Bank 1 near the firewall?
Bank 2 closer to the radiator?
StealBlueSho
My bad... thought we were taking the VCT....
Yes, bank 1 is close to the firewall... bank 2 is towards the radiator.
jay.denning73
I keep getting the same code for the Cam Position sensor bank 2. Thought I would start there..
Then vct if that doesn't help..
Best of luck, take your time, take pics of the uninstall steps to make it easier come install time.
jay.denning73
Mine wont be that bad, lol.
