post a new datalog of the issue in a 4th gear pull .. i'd like to peek at it doing the issue for 10 or more seconds.
fixing itself on a stop start suuuuuuuux, that means a sensor is bad or sending a bad/incorrect signal, or the ecu has a bad block that clears on reboot. does it fix itself EVERYTIME you do a 35 second cycle of having the car off... and how long in the start up does it run normal before the issue occurs?
and completely random idea.. does it do it COLD. IE water temp is 110f or less, and the car is still in ''warmup mode''. does it happen there at all?
