Bad BOV
Started by TASK_FORCE187, June 16, 2018, 06:52:02 AM
TASK_FORCE187
Can some please tell me why my car is doing this??????
https://youtu.be/MdbezMY9_N4
The Diaphram inside the BOV sounds ruptured !
Try to Disconnect the FRONT BOV HARNESS CONNECTOR & see if you still hear the sound!!!!
Did you ever get a chance to check for codes!   Z
TASK_FORCE187
Quote from: ZSHO on June 16, 2018, 07:02:25 AM
It doesn't have any codes. I just got my car back with a new engine. How would I tell them that my BOV sound weird with out them  knowing I disconnect them?
Quote from: TASK_FORCE187 on June 16, 2018, 07:00:09 PM
Bit of Trial & Error is sometimes called for! If you can simply unplug the BOV Harness connector to see if that flutter sound you hear goes away while driving!!!
If so just purchase a new BOV from the link provided above.....Its a mere amount to pay,especially if it avoids a dealer visit! Keep us updated & Simply trying to help ya out.  Z  :)
TASK_FORCE187
Quote from: ZSHO on June 16, 2018, 07:56:52 PM
I really appreciate the help.
I Guess you can also remove the Front & REAR BOV since they are the same identical part and inspect the Diaphram on each part for any notable difference.   Z
TASK_FORCE187
Quote from: ZSHO on June 16, 2018, 09:07:01 PM
I will. I will also take pictures to see if you see anything
It's hard to believe you don't have any codes when ur check engine light is ON in that video.
It sounds like it's building boost and can't hold it. I would check all clamps on the pressure side of the turbos.
Also check the hoses on top of the manifold to make sure they reconnected them.
TASK_FORCE187
Quote from: glock-coma on June 16, 2018, 10:36:42 PM
Very true. I checked with Autozone and the code was for the thermostat or it needed water. I called ford and told me that it was covered do to the engine being new.
Quote from: TASK_FORCE187 on June 16, 2018, 10:19:56 PM
Due post some PICS'!  I would love to take a gander @ the engine bay.  Z
TASK_FORCE187
Quote from: ZSHO on June 17, 2018, 07:52:11 AM
Here are some pictures
TASK_FORCE187
Quote from: TASK_FORCE187 on June 17, 2018, 10:38:56 AM
One more
The brake booster vacuum line by the firewall looks to be loose!
The IAT Sensor grommet coming from the MDesign intake seems unsecured IMO!
Did you try driving without the FRONT BOV Connected!  Z
TASK_FORCE187
Quote from: ZSHO on June 17, 2018, 11:43:21 AM
Can you point them out for me????
