June 23, 2021, 04:12:41 PM
Author Topic:  Dead Moon Roof? MKS  (Read 1254 times)
Offline Mksmark
  • Jr. Member
  • -Given: 1
  • -Received: 4
  • Liked:
  • Likes Given: 1
Dead Moon Roof? MKS
« on: June 12, 2018, 10:18:08 PM »
I have bearly used this thing and now it just does not move or make a sound. The shade still works and the fuse is good. I pulled down the switches and they check out working using a ohm tester. From what I understand there are 2 motors that drive this thing, one for the tilt and one to roll it back. I pulled the relays in the fuse box and checked each one and they are all working. I just don`t want to pull the headliner down to find nothing wrong. Anyone have this problem too? Oh and my cd player will not play cd`s. disk read error. Drives me nuts thx, Mark
« Last Edit: June 08, 2021, 07:17:44 PM by Mksmark »
Offline Mksmark
  • Jr. Member
  • -Given: 1
  • -Received: 4
  • Liked:
  • Likes Given: 1
Re: Dead Moon Roof? MKS
« Reply #1 on: June 08, 2021, 07:17:04 PM »
Found my problem after 3 years of looking. The motor for the sunroof and shade are the same and the drivers side failed. Another part make in Korea. You will need to drop the front of the head liner. Its not a easy job but worth it to have it working. Bought the motor from Amazon. Its a MM-992 sunroof motor. About $159.00 This is for the panoramic roof found only on MKS.
Offline Broodingrage
  • Newbie
  • -Given: 2
  • -Received: 1
  • Liked:
  • Likes Given: 8
« Reply #2 on: June 10, 2021, 07:50:16 AM »
Funny you should mention this, as I found myself in the same boat. Except mine was intermittant, I first thought it was the switch but a short time later with a multi-meter, I discovered is was indeed the motor. After some research, I discovered that the motor guilty of these pesky issues was right above my head. (2013 MKS Eco) Using my past skills in Car Audio (and all the tools needed to do this) I dove in. The headliner was like nothing I have ever seen, quite a few wiring harnessses that were literally hot-glued to it preventing a proper drop. That was the HARDEST thing to overcome, working with a 5 inch gap, at best. The motor came from Rockauto at about $135.
https://www.rockauto.com/en/moreinfo.php?pk=2604228&cc=1503893&pt=1536&jsn=1033
It was about a 3 hour job total, keeping in mind that my interior is a light tan and so there was much stopping and cleaning of my hands as I went to prevent staining of the headliner. It was well worth it, the Sunroof works perfectly and much quieter than before.
EDIT: There ARE two motors up there, Drivers side does Slide/Tilt and Passengers side just does the electric sunshade. After you replace the motor, you MUST do a
         motor initialization to get the motor to stop at the right points in travel. The steps are a bit convoluted (I had to write them down, I can supply them if
         requested)
I think a speaker upgrade will be next............ :bangin:
« Last Edit: June 10, 2021, 02:51:43 PM by Broodingrage »
Offline Mksmark
  • Jr. Member
  • -Given: 1
  • -Received: 4
  • Liked:
  • Likes Given: 1
« Reply #3 on: June 10, 2021, 03:22:32 PM »
Last night I took the motor apart and found that there was a controller board with the motor and a few drops of water must have got in there. The board was corroded. The motor still worked fine when jumped with 12V. When I got done installing the motor, I didn`t need to do a initialization. It was plug and play on my 2012. It stops at the right spots. I`m just glad it over. Now to figure out why I can`t play CD`s. P.S. I used to do car audio as well in the 1980`s. Things are a lot different today.
« Last Edit: June 10, 2021, 03:26:28 PM by Mksmark »
  • Newbie
  • -Given: 2
  • -Received: 1
  • Liked:
  • Likes Given: 8
« Reply #4 on: June 10, 2021, 03:57:19 PM »
Very interesting. After I had put the new motor in my roof, until I ran the initialization, the roof would only move if I held down the switch. It would dead stop as soon as I took my finger off of the switch. Perhaps a Body controller computer change happened in 2013 (??) Either way, congrats on fixing your issue!
And yes, as for the stereo in this beast, it's a speaker upgrade only (probably an additional amp on the new 10" sub in the back deck) I couldn't imagine a head swap! What a nightmare, I'm too old for that kind of hassle.
Offline TopherSho
  • Eugene Oregon
  • -Given: 504
  • -Received: 411
  • 1st boosted rig!
  • Liked:
  • Likes Given: 5
« Reply #5 on: June 12, 2021, 06:16:16 PM »
I have half seriously joke/warned my wife ... if the center console dies ... im setting it on fire
Best 0-60 public road 4.35s
* Recent Topics
Re: Verdict : Torrington bearing on the way out.
by TopherSho | Today at 02:24:46 PM
*final update on this thread*Finally figured out what made the last tr...
Re: Datalogging with SCTx4 Device
by ridered74 | Today at 12:23:20 AM
Thanks for this amazing write up. I'll be doing this today to sen...
by Scott13SHO | June 21, 2021, 08:03:06 PM
I sold my SHO today to Carvana.Why Carvana ?Why not? I havenít been dr...
Re: PPE catted downpipes missing 02 sensor bung
by Macgyver | June 20, 2021, 12:05:51 PM
Wow, the price has really gone up... but so has everything else.Had tw...
Re: "Complete" List of TSB's for your 2010-2012 SHO
by rdmccrary | June 18, 2021, 08:55:54 AM
TSB 10-22-4 AWD VEHICLES - SHUDDER-CHATTER-VIBRATION ON TURNS OR THUMP...
Re: Picked up an 18 Navigator
by jims2015 | June 18, 2021, 08:46:52 AM
So you dont get the $7500 off the sticker then ?Nope, you take it off ...
Re: Factory fuel pump specs
by Macgyver | June 17, 2021, 08:17:35 PM
Yeah but then you should need a LPFP to feed it and will it run off th...
Re: RockAuto.com Discount Code - Expires July 5, 2021
by Broodingrage | June 16, 2021, 07:33:54 AM
This vendor saved my wallet when I had to replace my 2013 MKS Dynamic ...
Re: Engine Fans start immediately Mks
by Matt_Sommers | June 15, 2021, 07:59:40 PM
Is the AC on? If yes, then the fans are supposed to be running.I didn&...
Re: 2010 ford sho blue smoke on decel
by 6500rpm | June 15, 2021, 04:37:07 PM
I  just ran my car in Oasis last week and was reading through TSB...
