Quote from: TimmyATL on June 06, 2018, 02:16:47 PM
no the widest for my bolt patter is 8.5
That is incorrect. I've put a snippet from the table found at (
https://www.tsw.com/alloy_wheels_nurburgring.php) below. It has all the sizes and color combos for each bolt pattern, etc. You can get 20x10 for the rear, which should be fine with that size tire, and is what BPD ran. Not sure of the offset he ran. You may be able to run 20x10 in front as well, but not sure on that.
You could also run 18s all around as they offer 18x7.5, 18x8, 18x8.5, 18x9, 18x9.5. You could probably do an 18x9 or 18x9.5 all around with a comparable width tire for an 18.
Part Number Size Bolt Pattern Offset Back Spacing Finish Bore Load Rating List Price Cap Part #
2005NUR255114G76 20x10.5 5x114.30 25 6.700 MATTE GUNMETAL 76.0 1650 460 CCPCG18F
2005NUR255114S76 20x10.5 5x114.30 25 6.700 GUNMETAL W/MIRROR CUT FACE 76.0 1650 460 CCPCG18F
2005NUR255114Z76 20x10.5 5x114.30 25 6.700 MATTE BRONZE 76.0 1650 460 CCPCG18F
2010NUR405114G76 20x10 5x114.30 40 7.000 MATTE GUNMETAL 76.0 1650 460 CCPCG18F
2010NUR405114S76 20x10 5x114.30 40 7.000 GUNMETAL W/MIRROR CUT FACE 76.0 1650 460 CCPCG18F
2010NUR405114Z76 20x10 5x114.30 40 7.000 MATTE BRONZE 76.0 1650 460 CCPCG18F
2085NUR205114G76 20x8.5 5x114.30 20 5.500 MATTE GUNMETAL 76.0 1650 460 CCPCG18F
2085NUR205114S76 20x8.5 5x114.30 20 5.500 GUNMETAL W/MIRROR CUT FACE 76.0 1650 460 CCPCG18F
2085NUR205114Z76 20x8.5 5x114.30 20 5.500 MATTE BRONZE 76.0 1650 460 CCPCG18F
2085NUR405114G76 20x8.5 5x114.30 40 6.300 MATTE GUNMETAL 76.0 1650 460 CCPCG18F
2085NUR405114S76 20x8.5 5x114.30 40 6.300 GUNMETAL W/MIRROR CUT FACE 76.0 1650 460 CCPCG18F
2085NUR405114Z76 20x8.5 5x114.30 40 6.300 MATTE BRONZE 76.0 1650 460 CCPCG18F
