Extended Warranty!
Started by TASK_FORCE187, June 03, 2018, 09:34:07 AM
Happens a lot, inconsequential.  you could put some silicone sealant adhesive on it and glue the cover back on.
TASK_FORCE187
Can I switch them to see if it that?
Quote from: TASK_FORCE187 on June 03, 2018, 12:36:58 PM
Quote from: TASK_FORCE187 on June 03, 2018, 12:31:36 PM
I did put my finger inside of it and noticed a little bit of oil. Should I change the Rubber seal
That dont sound right. Lol
Naughty,naughty! Lol.  Z  :D
Davidsiebert2
We just fixed my buddy's, his lepta opening and closing when crusing because the factory crimped pressure hose going into the innercooler was leaking at the plastic crimp
SM105K
Mine kept going off because I had a boost reference hose fly off under the cover.  I thought it was the BOV and pulled and inspected them.  The were good. I zipped tied the hose back on.
