Updates in progress.
Started by dimspace, August 15, 2013, 10:31:11 AM
dimspace
Tapa talk issues fixed
Sent from my GT-I9100 using Tapatalk 4
Good job! Seems to be working fine now!::):D
Sent from my DROID RAZR using Tapatalk 2
I checked a little while ago and so far everything seems to be functioning just fine.
Good job and thanks for all the hard work.
Sent from my DROID3 using Tapatalk 6
dimspace
We are running the unreleased tapatalk plugin now, took it straight from their github and it seems to have fixed the issues. hopefully they will release that officially soon.
Support can make/break a software platform, glad the "beta" release for TT is working nicely.  Thanks for getting this done!
Larrylu
I'm not seeing the "thank you" that was available for a while earlier on TT.  Am I just not looking in the right place?
dimspace
#21
Quote from: Larrylu on August 21, 2013, 08:49:33 PM
at the moment, in the new version of tapatalk, i understand that thank you is not supported as they made quite a lot of changes to the structure of the program. They are releasing all their code on github so external devs can implement things, so i will pester the creator of the thank you mod to get them to parse the changes across. failing that I will have a look at it myself.
thanks for your patience guys,. with all new communities there are teathing problems. weve discovered a couple of bugs with packages, and also issues with the instant messaging which was slowing things down. Boss is looking at a new server over the next few days. if there are issues the boss can usually solve them, if not, im usually available.
Larrylu
Quote from: dimspace on August 22, 2013, 09:06:01 AM
The things you guys play with is amazing to me!  Thank you.
