Aluminum end tank OEM style intercooler
Started by 2013blksho, April 27, 2018, 07:15:40 PM
lamrith
So by the looks of it this new unit still fits between the AC and Radiator cores?
Colorado-SHOBro
Quote from: lamrith on May 02, 2018, 04:45:23 PM
yes i've looked into this intercooler as well. it fits the exact same as stock. another local had one at one point and considered it a very minor upgrade at best. id say it's a viable option if you're needing to replace your oem intercooler already but not worth it as a performance upgrade.
i am anxious to hear the op and brads feedback after reviewing logs though
12.8@108 @ 6,000ft DA.
2013blksho
talked with Brad and the intercooler is a good OEM replacement. didnt see any real performance gains as far as that goes but if you need a new one like i did I would check them out.  the fit is great and the temp were in line with stock intercooler.  no special hoses clamp tubes all factory.
avidmotion
Any new updates? I still looking for an improved CAC....maybe add a damn fan or watermist or something!
