Is my turbo(s) Bad?
Started by 2010Limited, April 23, 2018, 09:45:31 AM
If you find a way of taking the actuator rod/lever off, let us know.  I have not seen an official procedure to do so in the manual.  Might be a replaceable seal that's all that's needed, but just guessing here.
Def no leaks from the PTU though, right?  Maybe clean off the gunk on the actuator and see if it comes back?
2010Limited
Quote from: SHOdded on May 04, 2018, 11:44:14 AM
Maybe I'll clean as best I can and see. Not sure if the PTU is leaking. I hope not. I love this truck but it's becoming a PITA
2010Limited
Pulled my rear turbo exhaust pipe and found this
Gray Brick
2013 Ecoboost Ford Flex
2010Limited
Quote from: Gray Brick on May 04, 2018, 04:02:02 PM
Condensation or oil?
Mostly oil and the same nasty crap that was in the separator
Gray Brick
I would guess mine are in similar shape at 130k miles.
A little smoke on startup but nothing crazy.
2010Limited
Mine smokes bad enough you can't drive it
2010Limited
Just found this! Guess my rear turbo is toasted!
lamrith
Quote from: 2010Limited on May 07, 2018, 07:53:40 AM
That'll buff right out.
Joking aside, sorry to see that failure, but now you know the source of the noise you heard, the milkshake in your exh pipe and the smoke.  At least turbos for these cars are relatively inexpensive.  Damage like that you are going to need the entire turbo and cannot replace just the CHRA.
Big question now for you is, do you stay stock or go ATP.
2010Limited
Quote from: lamrith on May 07, 2018, 11:28:45 AM
I'm actually glad I found the source of the problem. I'll just stay stock. I don't trust the rest of it now
