OK, well the turbo is rebuilt and back in. Almost no blue smoke at idle....BUT with throttle it is still smoking. My plan is to pull and rebuild the rear turbo as well.
When I got the front turbo out, I noticed it was an aftermarket turbo. These were supposed to be replaced at the ford dealer in 2013. Anyways there was a leak at the feed line and come to find out the copper washer was on top, and the lower had a felt washer. I put it back together with the correct dual copper washer set up and it still leaks! No matter what I do I cannot get it to stop dripping.
Has anyone run into this problem with the oil feed not sealing?
