Been pulling axles and grey hair trying to get this all sorted out and now have the good fortune of hard shifts into D and R from P. Just when I was getting the hang of feeling good about the first real repair executed, this happens.
I did eventually manage to get a new seal into the differential and was pretty pleased that it went off with only 4 attempts of making seal seating tool which was easily corrected by going to the plumbing section at the local hardware store in the finale. ABS, crazy carpet and bolts, in no particular order or function, were able to install the seal. By the time the seal did go in, there was a lot of ATV gasket maker on the perimeter of the seal to amend early install attempts damage. A quick 20-minute test and smile later, not a leak and disaster averted. Not 2 hours of driving later does the hard shifting enter the fray.
Question: With the new hard shift into D and R --but otherwise relatively familiar feeling shift quality while driving-- is the pinion bearing a possible fault for the hardness into these initial gears?
Morning startups on the cold motor seem to really exacerbate this condition and when I initially start to roll forward the car lunges into about 10kms/hr right off the line. I suspect reverse will behave similarily in this morning test but haven't tried. This condition does lessen greatly as the motor warms but a hint of this remains even on a warm motor.
Questions:
1. Should I be looking at trying to get the bearings all replaced in the differential if it is possible?
2. I am at the mercy of the tranny shop, but will an attempt to limit my exposure to excessive rebuild costs be limited by delivering the differential pulled from the car?
3. What might be a good estimate of cost for replacing all the bearings only?
4. Can the bearings be installed with a common tool if I go buy a used unit and attempt to do this myself?
5. Knowing myself I should ask: will doing nothing give me a better return on my investment at this point?
? I think I see the pattern here so just ignore this last question please:)
All advice is great and appreciated.
Cheers
