Started by avidmotion, March 26, 2018, 02:00:24 AM
avidmotion
Has anyone run the 275 40 20 on a stock suspension (no H&R springs), and not had rubbing or ABS problems....2013 +PP SHO
derfdog15
I don't see why you would have ABS issues unless you only changed two tires, as long as all 4 match ABS should be fine, as will the AWD system. If you differ front and rear by 3% or more you may have AWD issues.
Since the 275/40/20 will fit on a lowered SHO, I see no reason to expect issue on a stock height car.
ryanp49
Had no problem on my car at stock height!
lamrith
Quote from: avidmotion on March 26, 2018, 02:00:24 AM
Much will depend on the wheel choice.  275 will not go on stock wheels from everything I have read.  What wheel are you looking to go to?
StinkinLinkin13
Any pics of this would be nice for sure...
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
avidmotion
I was looking to stay on stock rim. I think i will do 255 45 20 with the new GMAX RS summer tire, word is they are awesome. 135 shipped for the 245, 360 AA A
jman
I got 275 40 20 with H&R springs, no rubbing. Car looks great with these.
2010 - Unleashed Tune - Corsa Exhaust - 275/40-R20 - H&R Springs
Colorado-SHOBro
Quote from: avidmotion on April 04, 2018, 11:07:46 PM
according to their spec sheet online the RS isn't made in a 255/45/20. have to stick with stock size or push your luck trying to mount a 275/40/20 on the stock rim
12.8@108 @ 6,000ft DA.
Colorado-SHOBro
Quote from: jman on April 04, 2018, 11:44:02 PM
How wide are your wheels jman?
irondoor19
#9
Quote from: Colorado-SHOBro on April 05, 2018, 11:16:35 AM
not trying to hijack but:
2011 PP with H&R's, Motegi MR120 Black 20 X 9 Wheels (W 275/40ZR-20 Pirelli P Zero's)
Colorado-SHOBro
Quote from: irondoor19 on April 05, 2018, 11:42:31 AM
^thanks that's what i needed to know. Been tempted to try 275's on my 8.5" wheels but don't really think that'd be a great setup.
irondoor19
ADDED a pic with the Stock blacked out 20"s and
then a pic with the Motegi's
jman
I'm not 100% sure, I believe 10". Will try to get a rough measurement tonight.
StinkinLinkin13
Quote from: irondoor19 on April 05, 2018, 11:51:59 AM
Kinda hard to see the stock wheels with the tires. How did that setup work out? Sidewall bulging?
Quote from: jman on April 05, 2018, 02:00:23 PM
Aren't 10" a bit wide for a 275?...BTW I love a 275/40 on the SHO...Grip monster....SHO bro I would put a 275 on a 8.5...Maybe a bit of a bulge but not bad...I have a 305 on my 9.5" mustang wheel...It's similar in terms of how much wider the tire is than the wheel.
