13+ Taurus Gt350 style front bumper
Started by Quikv6, March 16, 2018, 12:19:45 AM
gtmorgan23
The hood peaks my interest because it would allow the heat to escape through the vent in the middle.
2019 Edge ST "Phasma"
JLT Catch Can
StealBlueSho
Quote from: bpd1151 on March 19, 2018, 10:22:06 AM
Quote from: stealbluesho on March 19, 2018, 09:57:01 AMOn FB these guys are telling the 2010-2012 crowd to just do the front end conversion to a 2013+ front end so you can use their bumper.
Ha......
Well that would up the price exponentially.
Because besides the costs of this (potential) new aftermarket front bumper cover offering, those three model years would also have to purchase the 13+....
Engine Hood
Upper Grille
Pair of Head Assemblies
WOWSERS!!!
What about the front fenders? I am unsure if the 2013+ head lamp assemblies would mate properly with the 2010-2012 fenders? Not to mention if there are differences in mounting locations.
Quote from: stealbluesho on March 19, 2018, 11:16:44 AMWhat about the front fenders? I am unsure if the 2013+ head lamp assemblies would mate properly with the 2010-2012 fenders?
No change was implemented to the fenders.
The bean counters @ FMC stepped in and expressed their dismay at having to retool their stamping plant in Chicago Heights, IL. in order to produce new fenders.
Thus they remained unchanged as a result.
Also why the "only" change to the head assemblies was on the inset exclusively. The outer portions were kept the same for the very reason of mating to the '10-'12 fenders.
Surprised no one ever mentions shosource.com, I guess they are unknown to Gen 4+ guys?  Anyways, here is something you could look into if you want to get a CF hood.  Call them up and have a chat :)
http://www.shosource.com/catalog/product_info.php?cPath=60_98_99&products_id=685
would be neat to have a competing product to choose from, of course!
StealBlueSho
Quote from: SHOdded on March 19, 2018, 11:26:51 AM
I am familiar with shosource.com... I believe they need 10 pre-orders to start the process as they don't have them laying around. That is the last I heard.
StealBlueSho
I was tossing around the idea of the CF hood from them.. trying to figure out where I can shed some of this pig fat.... unfortunately... $1000 after shipping etc for about 40lbs of weight loss wasn't worth it for me to investigate much further. If I was running 12.01 consistently maybe :-P
Weight loss AND bling, can't discount the BLING!
StealBlueSho
Quote from: SHOdded on March 19, 2018, 11:45:58 AM
Dude... with me in the driver seat that is all the bling you need!
Well blling you may think you behold, but that certainly isn't helping you out at all in the weight reduction category.
Maybe you'll wanna flip that $1k for those 40lbs. after all.
Bwahahahaha. Poke. Nudge.
StealBlueSho
Quote from: bpd1151 on March 19, 2018, 12:41:22 PM
I see you installed your emotion chip today and have jokes huh? Lol..
Quote from: stealbluesho on March 19, 2018, 01:32:20 PMI see you installed your emotion chip today and have jokes huh? Lol..
I DID !!!!
Working as designed I might add !!! LOL
J-Will
Quote from: stealbluesho on March 19, 2018, 11:44:12 AM
Weight reduction *could* prolong the life of the drivetrain
3-bar
SP-542 plugs w/ GH gap
StealBlueSho
Quote from: J-Will on March 19, 2018, 02:02:28 PM
Maybe... not sure if 40lbs is gonna make a huge difference.. but every little bit helps? Maybe I should take the hood off next time I got to the track and see what difference it makes?
derfdog15
I don't think 40lbs would be worth $1000, or have any noticeable benefit. The general rule of thumb for performance is 100lb = .1 off of 1/4 mile ET, so you would see MAYBE .04 off an ET, not worth it, unless like Stealblue said, you were right at the cusp of the next bit number (ie. 12.01).
There is a larger variance than 40lb in drivers alone, plus family/passengers, spares, luggage, etc. I ran 14.4 stock in my SHO with the added weight of an AMR 20x8.5 wheel and BGF 245/45/20 mounted, plus a jack, and 100 something piece tool kit. I ran 14.2 to 14.3 later that night taking that stuff out, and brake boosting slightly more.
IMO the carbon fiber hood is only worth it for the bling, and it likely still has some steel, etc. in it to retain stock functionality/mounting. If it were a true racing, Pin on only, hood, it would save a lot more weight and could then maybe be worth it. Or if you needed additional clearance and it was a cowl.
With regards to this front bumper, I would expect more weight due to the splitter etc. and it may reduce ground clearance past an acceptable level on a lowered SHO with that splitter. It would depend on driver, and roads with regards to ground clearance, some people, like BPD can handle a pretty low ground clearance, but he likely plays is smart with where he travels in the SHO, and obviously has some experience with getting the right angle of attack if he does have a clearance issue somewhere.
I'm interested to know if there is a difference in the 10-12 front end mounting hardware/headlights weight vs. the 13+ setup weight. If so that may be even more added on to the 10-12 owners plates if they only make a 13+ version.
derfdog15
Quote from: stealbluesho on March 19, 2018, 02:15:27 PM
I think that would depend on the track, some may not let you drive it without a hood depending on the type of track/event. That said, you'd save more than 40lbs there for sure, probably closer to 75lbs, maybe a bit more. But you may add some drag and thus lose performance. But you'd be running cooler presumably so maybe gain some of that back. Its kinda a crap shoot in the case of no hood IMO.
