Opp or opt for meth
Started by Dxlnt1, March 03, 2018, 09:30:07 AM
Dxlnt1
Don't remember who, but Im coming into Arizona next weekend (3/9/18). I am wanting to see someones meth install preferably on a SHO.
1. Is anyone available to show me their install?
2. Is anyone available that can perform install if I choose to do so that weekend?
3. Cant remember company but any benefit doing typical install vs the port injection manifold? Seems in Ventura, CA somewhere
AJPTurbo, I think your tune was able to get good numbers without meth. If its you in Arizona can we meet up to discuss?
Nope I'm in Pennsylvania!
The direct port is probably the best way to go but I'd say not necessary. With Direct port you won't see the cooling but that doesn't really matter since the octane is there
Trying to recall (as it's been many years) since my install.
I think mine took just under 10hrs total.
But that's with a 2nd person assisting, and both being proficient/familiar with the necessary procedures involved.
The individual port install looks cool, and distributes the meth in a more even matter across both banks, but there's no proven improvement in performance per se.
Save the expense IMHO. Good luck!
Dxlnt1
The company was Prometh.
https://prometh.com/collections/nozzles-nozzles-packages
However the SHO manifold is not on there website anymore. I read somewhere for the "extra" cooling affect a 7th nozzle was installed before the throttle body.
From an economical standpoint the AJP tune may be the better choice. we Spoke briefly on the subject, Im was trying to justify spending anymore on this car. And still unsure but I am also considering relocating to Arizona in couple years!
If relocating to AZ, you would want to look at upping the E content also, if not completely upgrading to E85.
Quote from: Dxlnt1 on March 03, 2018, 10:52:59 AM
That is kind of dumb and a waste of money and work to be honest...You don't really want or need the cooling just for the sake of cooling...Think of it this way, if your IAT's were 200 degrees but you had no knock or knock retard because you had  super high octane fuel then what is the point of cooling the air charge?
Most people that add intercoolers or true cold air intakes think they are doing it to because the colder air charge is better at resisting pre-ignition and that is somewhat true but the real benefit of cooling the aircharge is that the ECU won't have to apply the IAT spark compensations and that is where the real power comes from.
Turbo dragsters have the compressors feeding right into the intake manifold with NO intercooler so the charge air temps are really high but it doesn't matter because they are using alcohol that cools and has super high octane
Quote from: AJP turbo on March 03, 2018, 12:15:04 PM
Speaking of fuel engines used or dragsters and funny cars, the turbo is a rarity anymore as most use superchargers again feeding directly into the intake. The alcohol dragsters/funnies do use alcohol but the nitro cars are usually only running about a 10% alcohol fuel. Just FYI.
Dxlnt1
Good point. I still would like seeing an actual install. I don't like a upgrade to look like a upgrade. A true sleeper is all go and little show. That's been my premise for all my changes on all my cars.
StealBlueSho
My install took around 8 hours, but I leaned heavily on BPD1151's How to post(Thank you again) which made things much faster. IE.. not having to search for the correct fuse to tie into etc...
If you were to look under the hood of my car nothing but the AIRAID stands out.. you wouldn't even know my car is meth injected unless you knew what to look for and were familiar with the engine... works well at the track when running N/T's...
I did go with the Alky kit as its reputation and that of the owner is stellar.
Skydogs
 Mine took about 4 hours but I did it at my shop. Lift...tools.. ect ect.
Boost and meth life!!
13 SHO PP  Meth tuned by AJP Turbo!!!!
610" Merlin 8.3 whipple on Meth 1,300 HP Pump gas
17 Thunder Cat 300 HP Tuned
17 X3 Can-am 200 HP Tuned
I guess a bit late to the party but it took roughly seven days as promised by LMS to have my custom (DPM) installed which also included a Dyno tune plus installation of new spark plugs and front primary 02 sensors @ LMS Facility last year.
Dave Best of luck and any questions you may have always feel free to ask brother.
Here's my very own Build thread below.  Z  :)
www.ecoboostperformanceforum.com/index.php/topic,7881.0.html
I've been thinking about removing my intercooler...
Quote from: FoMoCoSHO on March 21, 2018, 11:34:13 PM
I don't think I would do it for your application....It is still helpful and it's not big enough to hurt spool so I'd leave it.
J-Will
Just drill a hole in the piping. The benefits outweigh the damage
/Sarcasm
3-bar
SP-542 plugs w/ GH gap
SilvererSHO
I'm not sure I'm following you on this one?  Your first and second paragraphs contradict themselves.  A cold charge is denser, less prone to detonation and you are able to throw more spark at the motor whether it's done with an intercooler, water, meth or any combination of the three.
A turbo dragster would make more power with a HUGE intercooler but I'm sure it all comes down to packaging in a dragster.  And forget about an air to air intercooler.  It would be heat soaked at the starting line and never really have time to drop temps by the time the run is over.  Plus, like you said, running alcohol cools the charge AND they are way more over fueled than a street car giving it more effect.  I wonder if they inject water at all?
All Silver(er)SHO.  2012, every option with PP running new Firehawk Indy 500's.
