Running with the bull (cinnamon/umber content)
Started by Code AiR, February 04, 2018, 04:19:29 PM
Blackhawk
Factory 19s, good chance it isn't a PP unless someone swapped them previously.  Doesn't really matter much anyways in the grand scheme of things.
dubcitySHO
#31
Quote from: ZSHO on March 14, 2018, 10:45:04 AMIMHO from the color scheme to the wheel setup wouldn't even care if its a Performance package or NOT...from my perspective it simply looks that dam good! enjoy.  Z  :)
My thoughts exactly.  I've always loved the Cinnamon and the wheels definitely make it pop even more.
Plus once you get a tune the gearing advantage of the PP more or less disappears.
2018 Magnetic Metallic F-150 XLT FX4 SCrew, 20% 3M Tint, Currently researching reputable F-150 tuners....
Quote from: dubcitySHO on March 14, 2018, 01:14:32 PM
@ dubcitySHO That candy apple SHO of yours leaves nothing to be desired.  Z :thumb:
Quote from: Blackhawk on March 14, 2018, 11:05:40 AM
It matters when you have an MKS and you are gathering impressions of the different suspensions on H&Rs before a final decision is made. The MKS gets base shocks so the only upgrade path is to rob the SHO parts bin or coilovers. I do not want to put a third suspension on because I chose wrong.
I had two gen 5's one PP, one non, and I much preferred then standard package. IMHO not enough of a performance increase to justify the harsh ride.
Blackhawk
I'm glad it matters to your specific case.  To the OP I was just assuring him he isn't missing much not having the PP.
Quote from: FoMoCoSHO on March 14, 2018, 02:19:59 PM
Code AiR
Quote from: ZSHO on March 14, 2018, 07:00:20 AM
@ Codeair is there a spare tire in the trunk?   Z
I haven't checked yet I will when I go on lunch break though.
Ignorance is curable (with knowledge), stupidity is not.
Code AiR
Quote from: Code AiR on March 12, 2018, 08:10:51 PM
Quote from: FoMoCoSHO on March 12, 2018, 01:16:56 AM
Quote from: Code AiR on March 07, 2018, 02:41:22 PM
I think it could be a little lower. I am not "really" happy with the height but it's my daily so I don't rub and have full function. So it is what it is. The space in the rear is really bugging me with my new Roti's. Wheel specs; f20x8.5 / r20x10 .... Tire specs; f255/45/20 and r275/40/20
Really?
I'd be unbelievably happy how the drop and wheels turned out, its perfect!
Is yours a PP on non-PP?
Honestly idk lol. How do I tell?
Thank you sir! Hopefully I can keep improving the aesthetics.
Code AiR
#37
Do the PP's come with water-to-oil coolers that are plumed into the radiator core? I mean I guess it doesn't matter really I am going to go with drilled rotors and upgraded brake pads anyways. I already have H&R springs so that's taken care of. The only thing I wouldn't have is the gearing which from what I've read doesn't matter if you get a tune anyways. Plus the water to oil coolers. I guess I could upgrade the radiator if I wanted to.
No water to air coolers, assuming you are referring to the intercooler, in any SHO thus far; it is all air-to-air, hence the need for aftermarket solutions.  The advantages of PP really manifested with the Gen 5 because of the upgraded oil and trans fluid coolers, which can be used in Gen 4 applications, thanks to the detailed writeups by bpd.  Noone has attempted a radiator upgrade thus far that I know of, though I THINK bpd has upgraded fans?
A stroll through the HOWTO section is a good way to generate some ideas to make your Bull more ferocious :) and lighten your wallet (helping your ET's)!
https://www.ecoboostperformanceforum.com/index.php/board,107.0.html
Code AiR
Quote from: SHOdded on March 14, 2018, 05:58:25 PM
Guess I know what I'll be doing in my spare time tonight at work. Thank you! I was going off a post from another forum. I had to double check on which gen the guy was referring to. It was posted in a 4th gen section but maybe it was referring to an older generation. *shoulder shrug*
Mike's contributed a lot from what I've seen on this forum.
Well, the whole topic of Gen 4 and Gen 5 has been muddied for some time, and a separate section for Gen 5 was never created as a result.  We used to call them Gen 4.1 and Gen 4.2, so Gen 4.x :)
2010-12 SHO = Gen 4
2013-??? SHO = Gen 5
markssho
Looks great, wheels are awesome.
Bring it up I81 to the Ford Nationals in June. We'd all love to see it!
Mark
Sent from my XT1094 using Tapatalk
Code AiR
Took advantage of one of the few sunny days we've had.
Code AiR
Quote from: markssho on March 17, 2018, 08:48:22 PM
Mark
Thank you very much! Where does this take place at?
