Quote from: stealbluesho on February 01, 2018, 01:13:54 PM
I will tell you this... and I have mentioned it before.... to date, I have not had an SCT based tune regardless of tuner that runs 100% all the time. Torrie flat out couldn't get my fuel pressure under control among other things... BCB damn near blew up my motor with their 2nd revision(going 1.14 lambda in the middle of a boost spike will do that) and then told me that I don't have enough tables for them to work with.... and Brad has spent HOURS working my tunes over to come up with a tune that flat out runs 99% of the time. I still get a stutter in the upper RPMs once in a blue moon....
A lot of those TSB are resolved with a strategy update which you have the latest... so I dunno dude....
I am not sure it's mechanical since it runs fine after a flash....
My only concern 'when it worked' was the tiniest of a flutter at the top end of third. It may have been working... but now that it regressed i wonder if it was really WASN'T working all the way.
And i'm on my last purchase. after that i'm hosed
i still need to confirm :
-the tranny log i will go and collect today is clear of obvious bad stuff
-installing the new hand built 15-pound tune does not solve to for more than a few days.
then its
-new pcm, but that look like 600$ as the ones used i have seen do not list my PN as a direct replacement.
-livernois, they run lower boost, lower spark but modify cams,wastegate profiles to run high rpm to achieve their stats, MAYBE my version of the platform just doesn't run highboost well.
-buy a new transmission for the TSB's that might in play out of pocket
-return to stock and sell and get a 2011+ with a better damn ECU
FYI
battery us 14.2 + volts under full acceleration
oil is above board
Tranny fluid was *perfect* super duper clear and smelled fine, i added like 1/3 to 1/2 a additional quart anyways.
i will try to do the PCM inspections today if the cowel is easy to remove. i will be on single parent duty until the Mrs. gets home. So if its complicated i will loose bits
check list?
pully thingy bob 10$
CRC cleaner
What kind of goo should i be using to slather the connector to prevent corrosion ?
