Calculating 0-60 times from datalogs
Started by Agentlongwood, January 18, 2018, 12:29:18 AM
Agentlongwood
Is it reasonably accurate when you calculate your 0-60 time from a datalog?  I did this on a couple logs and got 4.8 seconds consistently.  A friend asked about 0-60 on my car and this is the only way I have to answer, lol.  I don't have any instruments specifically for measuring 0-60.  Wanted to ask yall if this method if accurate before I get back to my buddy.  Thanks.
2014 Lincoln MKS - Sold... And I still miss it sometimes
Using a tuning device, yes, should be consistent.  Using software like Torque Pro, not so much.  Aeroforce gauges are also very consistent with times.
Gray Brick
2013 Ecoboost Ford Flex
AJP Tune (ATP+2) in progress , Livernois HPFP, 3 Bar MAP, UPR Catch Can, 100% Methanol w/ braided steel lines, 3" Downpipes -->2.5" X-pipe --> 2.5" Magnaflow exhaust, 2.5" air inlets to each turbo with cone filter, Custom water to air intercooler with chiller
275/40-20 Front 315/35-20 Rear Tires
---12.419ET/112.43MPH @ 5150 lbs in the 1/4---
boostedflex
I am not an expert but I would think so.  For what it is worth I used my data logging 0 to 60 as the number I quoted for my Flex.
2017 Explorer Sport
Stock
2012 Flex, sold
Unleashed 93 tune, 170 degree t-stat, Airaid intake, Motorcraft SP534 plugs
Brucelinc
#4
I can't really speak for datalogging but my Aeroforce gauge matches nearly identically to the 0-60 calculator here in this link.  Lots of other interesting calculations, too.
http://www.wallaceracing.com/0-60_equation.php
http://www.wallaceracing.com/Calculators.htm
Agentlongwood
#5
The way I did it, specifically, was to get a datalog using my SCT X4 at the track.  I then imported the log and read the columns for Time and Vehicle Speed, in Excel.  This gave me 4.808 to 4.835 seconds, depending on run.
Bruce, if I use the calculator you linked, it gives me a 0-60 in an estimated 4.37 to 4.44 seconds.
That seems like a non-negligible difference.  I'd love for the quicker one to be more accurate, but my gut always tells me the slower number is usually the accurate one when it comes to these things, lol.
GT500R
The answer is somewhat... I would say more accurate then an app in general.
My examples, I have a VBOX (look it up, it measures 0-60 at a 20mhz rate (maybe more?) and it extremely accurate (when I took it to the track it was within .05 ET and .5 mph from the actual track time.
When I was running a test for AJP, my Vbox showed for true 0-60 with no launch -
4.97 s
5.05 s
5.09 s
My logs showed
4.68 s
4.76 s
4.82 s
So somewhat accurate, but I do have winter wheels on so the speed would be a little off anyway (~+2 mph) and if I add those 2 mph my 0-60 is 5.07 per log vs. 5.09 per VBOX.
So as long as you have 100% accurate tire ratio for the speedometer and you are on a level ground, I would say its pretty accurate.
2015 Edge Sport
Unleashed Tune | K&N Filter | Trans Mount | CXRacing Intercooler
1/4 mile: 13.228 @ 103.27 - 93 Octane
1/4 mile: 13.162 @ 104.67 - 100 Octane
1/4 mile: 12.999 @ 106.51 - E30
Brucelinc
Here are the Car & Driver acceleration times for a 2016 Mustang GT.  They list 0-60 in 4.3 and the quarter mile in 12.9.
A tuned SHO or MKS will beat a stock Mustang GT any day of the week especially from 0-60.   That is why I think the Wallace calculator and Aeroforce gauge are very accurate.
StealBlueSho
I have looked at 100's of datalogs between myself and users posted. I can that its "fairly" accurate HOWEVER, keep in mind that 0-60 performance does not equate to a clean 1/4 mile conversion..
Wallace calculated my 1/8 mile @ 7.94 second to a 3.86 second 0-60.. but I sure as heck didn't run an 11's at the full 1/4 track FWIW...
GT500R
Quote from: Brucelinc on January 18, 2018, 11:24:52 AM
Wallace calculator is somewhat accurate also.  But you can't define the 0-60 as you would with an actual VBOX.
I agree a tuned SHO or MKS will beat a stock GT.
2015 Edge Sport
Brucelinc
Where our cars shine is from a dig up through the 1/8.  After that, the friction of AWD and boxy areodynamics hurt it.  For us, the calculator is not particularly accurate in predicting a quarter mile time from an 1/8 mile time or a 0-60 time.
With a good tune and a fairly aggressive launch, our cars will run 0-60 in 4 seconds flat.  With a good Ethanol based tune or meth, 3.7-3.9 is doable.  That doesn't necessarily mean a quarter mile in the 11s, though.
f8tlSHO
I use my logs for 0-60 with stock tire size, ran a 12.4  my 0-60 was 4.1 or 4.2 from this log... I think this method makes the most sense as long as the correct tires are on the car.
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
Macgyver
Since we are extrapolating 0-60 from data logs and such. Working with a Tuned SHO. What does Two Octane points gain in performance on the same car. So 87, 89, 91, 93 octane. ( Pffft who needs 92 lol )
Anyway,
I know our small turbos run out of performance but I am talking about keeping them within their efficiency range using Say a numerous Datalog submitted 3 Bar Map tune.
Are the gains linear so that you could run an Excel chart and predict what gains you would get for the octane examples above ?
StealBlueSho
Quote from: Macgyver on January 20, 2018, 01:50:10 AM
Anyway,
This is a hard question to answer.. every car is a bit different, and not everyones 93 octane suppresses knock as well either... but in general we are boost limited due to fuel pressure IMHO.. the extra octane allows for more timing to be added.  So I wouldn't go as far as to say its a linear progression in power.
lnferno
I'd highly recommend getting a Dragy device.  They are only $150.  They are extremely accurate - proven to be within hundredths from actual timeslips.  You can measure your 60', 0-60, 1/8 mile, 1/4 mile and a lot more.
2018 Ford Explorer Sport
Some say the outline of my left nipple is the exact same shape as the Nürburgring
