Car leaking oil,smoking from exhaust oil Sep Fix!
Started by Colorado-SHOBro, January 16, 2018, 11:55:29 AM
Gray Brick
#15
I was having smoke on decel after being on the throttle.
Changed the PCV valve and separator... added UPR catch can. No more smoke.
2013 Ecoboost Ford Flex
Colorado-SHOBro
Quote from: Gray Brick on January 16, 2018, 06:29:31 PM
just read through your other thread. thanks for updating. so you just replaced the oil separator and not the valve cover correct?
i pulled off the separator and it looked far worse than yours did. all sorts of milky crud in there and  the pcv valve. ill get pics of it later. picking up a separator from the dealership now
12.8@108 @ 6,000ft DA.
Quote from: Colorado-SHOBro on January 16, 2018, 07:07:58 PM
The very reason i was curious to know!  Z   :)
Colorado-SHOBro
new separator on and problem solved! thanks to all who commented to help the diagnosis. once again the fine folks here have proved more than helpful.
here's the old separator. . nasty.
blew oil all over the rear of the engine bay
just got done cleaning stuff up and spraying down the map sensors. ill be doing a more thorough job on my upcoming weekend.
Interesting...Seems like the OEM separator works really well until full....I've always wondered why people install catch cans on these since they are basically equipped with one.
Seems like this should be a maintenance item.
Wonder if the 2.0 ecoboost has one?
pmezo33
Second AJP's call to make this a regular maintenance item.
polskifacet
#22
Before I saw this I also took off my separator. Looks to me like the oil drainback was clogged. I simple greened it for about an hour (fill, let sit in simple green, shake, rinse, repeat). There is another check valve or valves inside the separator. I blew and sucked the different holes (set my self up on this one lol) after cleaning and seemed like it was working properly. I also had about 1/3 of my JTL catch can filled with oil sludge which i had to clean with brake cleaner and a scrub with paper (I just cleaned it last week!!!!!).
Before this I also put a breather on the clean side and was getting some PCV smell through the vents on idle which is weird because it pulls a strong vacuum @ idle. Will continue to monitor, hoping we figured it out!!!
lamrith
For those of us newer to the platform can someone show us what/where this catchcan is?  Maybe a less zoomed in picture so we can see?  Sounds like it is possible to clean/empty it given Polshifacet's post, I want to make it part of my oil change routine moving forward.
Quote from: lamrith on January 17, 2018, 11:04:07 AM
It's the black box on the rear valve cover
Great to hear the Awesome news Colorado-SHOBro.  Z  :)
Highlighted in BLUE. Z
lamrith
Quote from: polskifacet on January 16, 2018, 02:17:20 PM
Looks like the oil separator is gone after 2014 SHO models.
The 2015-MY+ has an updated built in internal oil Sep inside the valve cover. IIRC.  Z
Colorado-SHOBro
Quote from: ZSHO on January 17, 2018, 11:59:42 AM
would be even worse if it failed then!! lol. but hopefully they've figured out a more durable design.
i considered cleaning mine after it was off the car since i didn't have the new one yet. i even tried to take it apart to no avail. in the end i'm glad i replaced it. there's less smoke out of the tailpipe than i've ever experienced . . even on cold startup. i would highly advise anyone to add this to the maintenance schedule.
also Z. . can you update the title of this thread to include "oil separator problem" or something of that nature. that way users in the future can search it out easily.
thanks
Quote from: Colorado-SHOBro on January 17, 2018, 12:40:28 PM
thanks
Will Do!   BTW it deserved a Sticky! Z   :)
