Nice write up lamrith.
Those upgrading speakers might want to add some sound deadening while you are in there and I have had great results with using foam to seal the door panel around the speaker so all the air movement is directed out the speaker grill and not caught in the door panel causing rattles/vibration. They sell FAST rings which re open cell foam so air can still pass through but using weather stripping close cell foam from the hardware store/home depot is typically cheaper and works better.
I'll make another thread on my system and challenges with upgrading to a DSP and aftermarket amps and speakers. After months and a few changes I am finally happy even if it not fully finished.
