120,000 miles. Oil is in the middle of the hashes on the dipstick. The CAC has 1/4" of crud. All plugs are very clean and compression is within 10% from cylinder to cylinder.
Runs like a champ.
Does anyone know the part number for the oil separator & PCV?
I would rather just replace it than put the car back to stock and bring it to the dealer.
SERVICE PROCEDURE
1. Remove the positive crankcase ventilation (PCV) Valve. Refer to Workshop Manual (WSM), Section 303-08.
2. Inspect for oil in the crankcase vent oil separator through the PCV valve opening. Is there presence of liquid oil, more than slight vapor?
a. No - this article does not apply refer to WSM, Section 303-00 for Excessive Engine Oil Consumption.
b. Yes - proceed to Step 3.
3. Replace the right hand valve cover, refer to WSM, Section 303-01D.
4. Replace the crankcase vent oil separator, refer to WSM, Section 303-08.
5. Drive the vehicle at normal operating temperature for 20 minutes at constant highway speed to remove oil residue from catalytic converter.
