BoostfoSHO 2015 SHO Build thread!
Started by BoostfoSHO, November 25, 2017, 06:39:55 PM
Since you changed the rear turbo,check the waste-gate hose coming from the IWG to your boost reference solenoid for starters...
Check all the clamps to verify there fully secure from the Charge pipes and CAC plus Rear turbo Piping. Z
PIC below for reference.,.
BoostfoSHO
Story of my life with this car. No matter what I do its never right. I'm probably not gonna work on it till maybe next Sunday  for now it'll just be parked.
After asking around and finding out last year on my own that trying to plug everything and pressurising the system is near impossible I'm probably gonna do break boost and spray soapy water as per mike b recommendation.
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
Ya leaks seem to be very evasive on your SHO :(
BoostfoSHO
Any ideas on what can be causing my wastegate duty cycle to run extra high? In my stockers I was running wgdc of 99% with the ATPs I'm at 89% but barely boosting 14ish lbs... I've inspected for leaks and also replaced the boost solenoid. I'm out of ideas I thought replacing my turbos would fix the issue but it didn't change anything. I'm near the point of getting rid of the car I can't seem to get it running right no matter what.
Any help would be appreciated.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
AJPTurbo FTW
2015 SHO PP
For now...
Quote from: BoostfoSHO on October 07, 2018, 07:09:40 AM I'm near the point of getting rid of the car I can't seem to get it running right no matter what.
I'm confused at your latest post, advising of your stereo upgrades (& requesting input on same) given your preceding post as noted above.
Are you now keeping the car, or what?
BoostfoSHO
Quote from: bpd1151 on October 18, 2018, 05:12:53 PM
Yea I decided to just keep it cause I'd be upside down and didn't want to take the hit so I figured I'd still go all out and finish the build. And I'm gonna adjust the wastegates and cross my fingers that it fixes my issues.
Sent from my SM-N960U using Tapatalk
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Installed my bc coilovers finally after 2 months of having the ride in my trunk. And also adjusted my wastegate ls a bit and I think it's definitely an improvement so I think I'm heading in the right direction, now to log and adjust some more if needed.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Audio build, Lots of pics. 4 days down 1 more to go.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
More pictures.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
More pictures continued.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Last of the pictures till tomorrow once everything gets hooked up. I'm gonna try and conceal all the wiring hopefully it will come out the way I'm picturing it.
AJPTurbo FTW
2015 SHO PP
For now...
Macgyver
That will take 2/10's off your 1/4 mile run. LOL
Looks good !!!
