BoostfoSHO 2015 SHO Build thread!
Started by BoostfoSHO, November 25, 2017, 06:39:55 PM
The SHO Shop offered 4 piston PBR calipers as an option for the 13" Baer Claw kit for the Gen 2's, IIRC.  I stuck with the 2 piston for cost reasons LOL.
I had one pic I was able to blow up and look at.
Apparently I need a photographer mod, lol.
I was able see through the hole in the caliper to see the piston which is NOT drilled.
I was unable to see the seals due to the angle.
Having had both types of brakes I don't think anyone will notice a difference unless the car is being tracked.
BoostfoSHO
So the power stop finally arrived but I haven't gotten around to put them on... Definitely not PP seals. But the powder coat is nice and heavy.
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
BoostfoSHO
#183
Finally got them on, I'm not gonna lie it was back breaking pain in the ass, for some reason I struggled a lot with putting the pads on with the clips and stuff. I took them apart a while ago and had forgotten how they went. Now I have the bedding process, so I'm not sure how they perform yet.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Hardwired my Uniden R3, I really love this radar has an unbelievable range.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Also detailed the ride inside and out.
AJPTurbo FTW
2015 SHO PP
For now...
Very nice!  That white paint really is gorgeous!
BoostfoSHO
Played around with the cell phone picture edit.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Hey guys so I'm still having methanol problems. I called devil's own and they say that for my set up I should be using a no10 nozzle which equals to 940mil/min at 200psi... I'm currently running a no5 nozzle rated at 520/mil/min at 200psi... According to both tuners who I've tried to get my methanol tuned with my methanol is non existent. It does read in the KR part but as far as cooling goes nothing temps keep creeping up. I've tested the pump and it does spray progressively according to boost. I've taken the nozzle off the pipe and activated the controlled and I get a real heavy fan spray. Can y'all tell me what size nozzles is the norm? I am in Texas and temps have been above 100° and at 3k elevation. The devil's own guy said that alone is enough to be using the nozzle no10
AJPTurbo FTW
2015 SHO PP
For now...
StealBlueSho
Hmmm... are you still running that add on for vacuum line on top of the intake?
It positions the map sensor up higher..
BoostfoSHO
Quote from: StealBlueSho on May 30, 2018, 05:52:57 PM
No I removed that back when you told me that may be the issue... I'm leaning towards not enough spray. Maybe nozzle too small.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
The guys at devil's own did they formula to get nozzle sizing and said I need at least a no7... Maybe I have been stingy on spraying too little.
AJPTurbo FTW
2015 SHO PP
For now...
The No 7 Nozzle sounds about right!
DO7 (640ml/min) Micro Droplet Methanol Injection Nozzle. Flow tested at 200 PSI. Z
http://www.alcohol-injection.com/en/nozzles/182-outside-mount-nozzles-do7.html
BoostfoSHO
Quote from: ZSHO on May 30, 2018, 06:16:52 PM
The No 7 Nozzle sounds about right! Z
Nice glad to hear it from someone else. It's been driving me crazy not getting this thing dialed in right since I installed the meth kit.
AJPTurbo FTW
2015 SHO PP
For now...
