Quote from: BoostfoSHO on April 01, 2018, 11:31:45 PM
Would something like this work as long as all the fittings have the correct sizes that one is just off the internet to connect to the break boost line and then from there have a line for the BOV and wastegate regulator mod and the methanol controller ?
A vacuum tree would work fine but IMO is a lot more than you need. IIRC you have EPP hotpipes right? If so, there MAY be a 1/8 NPT fitting under your MAP sensor (mine had one when I got it but IDK when he started putting them there). If you do, you can run your BOV reference from that, since its pretty close (you can get an 1/8 NPT to 1/4NPT male to male fitting (straight fitting), then a 1/4NPT female to 1/4 hose barb (90 degree), and run 1/4 line to the BOV. Then on the brake booster, they make a form of T that is actually a cross, you can use the cross block, with two 1/4 NPT x 5/8 Hose barb (if I recall size correctly) to tap into the stock hose, and two 1/4 NPT x 1/4 hose barb to run 1/4 hose to the wastegate regulator mod and the meth controller.
I have somewhat of a parts list and some pics littered throughout this thread:
https://www.ecoboostperformanceforum.com/index.php/topic,7171.msg109449.html#msg109449there were a few others that chimed in with other suggestions and parts/pics as well.
Good luck
